e46 knocking noise - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-20-2020, 08:55 PM   #1
bryanayala7
e46 knocking noise
when i get to a stop and idle, i noticed a pronounced "knocking" sound coming from under the drivers side foot-well. Just about where the dead-pedal is under my left foot. this only happens when iím at a stop light. iíve heard itís usually the heater valve that can make that noise.
It's as if someone is tapping on the floor with their knuckle.
bryanayala7 is offline   Reply With Quote
Old 01-20-2020, 09:07 PM   #2
cvx5832
My Ride: 535i, 325Ci, C300
Is it cyclic? Or only once as you come to a stop?
cvx5832 is offline   Reply With Quote
Old 01-20-2020, 09:44 PM   #3
swordsman11868
My Ride: 2003 325i
Transmission: Autotragic
e46 knocking noise
Yep I recently reconnected the fuses for my heater valve and I get the same knocking... again.
Now I remember why I removed those fuses.
And this is a brand new heater valve. Iím hoping to eventually clear up the IHKA errors using INPA.
I'm just here to change the world.
BMW Wiki:
Are you getting hot air no matter where you set your A/C in your E46? Check out this ancient thread! Chime in with your experience:
swordsman11868 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-20-2020, 09:53 PM   #4
bryanayala7
yes itís a constant cycle
Old 01-21-2020, 01:18 AM   #5
randy72877
My Ride: 01 330 sport 5m sil/
If it's the heater valve, it should stop if you turn off the heat. Simple easy and free to test.
Sent from my S61 using Tapatalk
randy72877 is offline   Reply With Quote
Old 01-21-2020, 10:34 AM   #6
bryanayala7
i donít even use my heater at all, iíve felt the heater valve after a drive and itís streaming hot
Old 01-22-2020, 06:06 AM   #7
markusmarkus
My Ride: 2018 M240i
e46 knocking noise
Thatís odd. Heck, hot coolant shouldnít be anywhere near the valve if the heater was off. I suggest you disconnect the electrical connector at the valve and see what happens.
Old 01-22-2020, 10:44 AM   #8
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Since the heater valve is normally open (when unpowered), I think turning ON the heat would be the test to do. OP is driving with the heater valve powered and in the closed position, hence why itís hot.
OP, use a mechanicís stethoscope to isolate the source of a noise.
https://www.harborfreight.com/mechan...ope-63691.html
BaliDawg is online now   Reply With Quote
