What is this wacky loooking washer - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-20-2020, 01:31 PM   #1
ssurfer4
My Ride: 2004 330Ci Coupe
Good day everyone,
I recently replaced my heater core in my 2004 E46 330ci Coupe. When I released the 4 bolts that hold the steering column to the dash bracket (4 large bolts) this fell out from the back left side of the steering column. I did not see exactly where it came from and I didn't remove any bolts/nuts from the steering column itself. I have looked at realoem, googled and even asked an online retailer with no luck.
Can anyone tell me what this washer is, where it goes? It looks like it is very specific to something.
Name:	dash washer 1.jpg
ssurfer4 is offline   Reply With Quote
Old 01-20-2020, 01:36 PM   #2
All2kool
My Ride: 2002 325Ci
Looks more like a retainer and not a washer to me.
Previous:
All2kool is offline   Reply With Quote
Old 01-20-2020, 01:38 PM   #3
ssurfer4
Any idea where it goes or a part number? I have been driving the car for about a month without it and no issues but still makes me a little uncomfortable not knowing. Thank you
Sponsored Links
Advertisement
Old 01-20-2020, 05:56 PM   #4
jdstrickland
My Ride: '94 325iC & '00 323i
It looks like a retainer to me, too.
Old 01-20-2020, 09:00 PM   #5
MoparJim
My Ride: BMW
Year: 2004
Model: 330Ci convertible
Transmission: Auto
Looks like a bolt retainer used to hold a bolt in place until its corresponding nut was put on. Probably nothing to worry about.
MoparJim is offline   Reply With Quote
Old 01-21-2020, 06:33 AM   #6
ssurfer4
That's the thing, no other bolt was ever loosened or nut taken off. Just the 4 large bolts holding the column up and it obviously did not come from one of those 4 bolts.
Anyways, it hasn't veered off the road or locked up so far.
Old 01-21-2020, 07:11 AM   #7
MrMCar
My Ride: E30M3 Track Car
Looks like the assembly "push nuts" that are used in a myriad of places.
I think (?) just might be one that holds some of the sound insulation foam onto a serrated stud under there.
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
Old 01-21-2020, 07:14 AM   #8
ssurfer4
Thank you, that gives me an idea of something to look for; but doubt I will spend hours on it. I haven't put on the lower steering column cover yet for this purpose. Thanks everyone.
Old 01-21-2020, 09:17 AM   #9
Geo31
Ironman
My Ride: 98 M-Z3/01 330iT 6MT
Looks like this: 64111364257
https://www.realoem.com/bmw/enUS/sho...diagId=51_3729
https://www.ecstuning.com/b-genuine-...h/64111364257/
Only place I can find it used is the door trim panel. Good luck.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 01-21-2020, 05:13 PM   #10
mrearly2
My Ride: Ilse
Year: 2003
Model: 330i
Transmission: 5 manual gears
It looks nothing like it, except for roundness.
If it ain't broke, don't fix it.
mrearly2 is offline   Reply With Quote
Old 01-21-2020, 08:45 PM   #11
IdahoDoug
My Ride: Quattro 20V
I wouldn't worry about it. It looks designed to hold something in place like insulation, or a wire loom that is not critical at all. It's kind of a "speed clip" like product for a pretty lowly function that is not critical. A dash pad on one of my cars (forgot now) was held onto the metal frame with about a dozen of these little clips.
1984 Porsche 944, 1987 Toyota Supra 5M Targa (project), 1987 VW Vanagon, 1988 Mitsubishi Van Wagon, 1990 Audi 90 Quattro 20V 5M, 1992 Lexus LS400, 1993 Toyota LandCruiser full spec, 1997 Toyota LandCruiser full spec, 2018 Subaru Outback, 2002 325Xi sedan full spec.
IdahoDoug is offline   Reply With Quote
Old 01-28-2020, 05:47 PM   #12
LeverThis
My Ride: 2004 325i automagic
Fwiw, check out the fastener at 0:42 or so ... pretty much the same thing. It probably holds on plastic paneling or aluminum heat shielding.
20mm OD x 12mm ID x 4mm W : Viton O-Ring
3/4" OD x 1/2"ID x 1/16" Thick : Thrust Bearing/Washer
LeverThis is offline   Reply With Quote
column, dash, steering, washer
