Overheating in Traffic | Electric Fan, No leaks? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 08-05-2019, 08:57 AM   #1
ivannikolaev
Hey guys,
I had recently purchased a 2003 325xi (Manual), a little over a month ago. Everything up to last week had been perfectly fine until I was sitting in some pretty bad stop/go traffic and looked down to see the temperature gauge rising rapidly. I immediately pulled over and shut the engine off.
I popped open the hood and looked to check for any visible leaks - I couldn't find any. I started the car briefly to check if the electric fan came on and it did. I ended up waiting a bit for the car to cool down and then drove it off the freeway, with the temperature gauge at normal, and then parked the car for 40ish minutes, after which I added some water into the expansion tank (the level was slightly low, but it was the same when I checked it a couple weeks prior, so I wouldn't think that there was a leak).
After that, I started the car and drove down the freeway, now in normal 65 MPH speeds, about 20 minutes home. I was very closely monitoring the temperature gauge, and it stayed dead center the entire way home.
I'm presuming this has something to do with the electric fan not coming on during stop/go traffic, but I really don't know.
What could this be? I flew out the next day for the next month, my car is sitting in my garage awaiting my arrival.
ivannikolaev is offline   Reply With Quote
Old 08-05-2019, 11:18 AM   #2
77'911
At a min, I'd replace the t-stat and install some fresh BMW blue coolant. The overheating in traffic sounded like a rad that needs replacement. For me, when our cars hit 100k(did them @ 80k on our 986), I change them out. They seem to loose there ability to cool around that time. It's also a good idea to clean out the condenser while in there. Rads are cheap for these cars, and they like to run cool(especially wt all the plastics).
My guess is the t-stat stuck for a moment. You might test the fan to see if it's working. On age alone, I'd replace the sensor in the hose. For me, it's a service item(like the head temp sensor), especially as these cars age. Good luck with it.
Regards
77'911 is online now   Reply With Quote
Old 08-07-2019, 05:47 PM   #3
My325XI
My Ride: 03 325XI Sprt Prem
Year: 2003
Model: 325XI
Transmission: Manual
I ran into a lot of the same issues last summer. I ended up replacing my electric fan.
2003 325XI 5-speed ZSP ZPP
My325XI is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-02-2019, 11:02 AM   #4
Astheros
My Ride: BMW
I had the same issue with mine some time ago... the electric fan module was bad
Evil men will triumph so long as good men stand by and do nothing.
Astheros is offline   Reply With Quote
Old 09-02-2019, 06:39 PM   #5
jmo69
My Ride: 03 325xi 98 328is
Mine never overheats, 150K and the 'crap' viscose fan. At least it turns whenever the engine is running.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
cooling system, electric cooling fan, overheating
