Overheating when in idle - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 11-01-2013, 04:53 PM   #1
Shockingtaco
My Ride: 2004 330I ZHP
So about 4 months ago I replaced my thermostat due to idle overheating, and a few weeks ago I was driving and as I came to slow down I noticed movement of the needle went right into red. I don't think it's the expansion tank because I see no fluids leaking out of the vehicle, both fans seem to work when the car is on, I get the loud fan sound when accelerating still, but the vehicle keeps overheating if idles for too long, since then I've garaged it and choose another vehicle. Any ideas as to what it may be? Thanks for any help.
Shockingtaco is offline   Reply With Quote
Old 11-01-2013, 06:41 PM   #2
lszlszx
My Ride: Z3, V50, 1.8T
Test the mechanical fan to be sure. Roll up newspaper and with the engine idling stick to the fan blades. If the fan stops easily, it's toast.
Other than that, maybe there is air in the system?
I would also monitor the exact temperature with the OBC, the temperature gauge isn't accurate.
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 11-01-2013, 07:14 PM   #3
jfoj
My Ride: 330CiC, M5, X5, E93
Also make sure your cooling system is bled properly.
Note that these thermostats almost always fail open.
If there is no air in the cooling system, also keep in mind the water pumps split on the shaft and the impeller can slip.
Check the 3rd link below in my signature for more thermostat and engine temperature info.
Check the temp on the Hidden OBC Menu.
Also check the sensor in the lower radiator hose, if there is any moisture on or below the sensor, replace the O-ring, part number is in my signature.
Solve your misfires, lean codes, rough idle -
Fuel pump failures -
Temp Info -
Hidden OBC Menu - Check Voltage, Temp, Fuel Level -
E46/E39 GM5 Door Lock Info -
Sponsored Links
Advertisement
Old 11-01-2013, 07:22 PM   #4
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Outback
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
sounds like a worn water pump.
VALMONT is offline   Reply With Quote
Old 11-02-2013, 03:04 AM   #5
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Likely you've got a blown head gasket. Air is getting pushed into the coolant causing massive air pockets and overheating.
Do this test when fully cold:
- crack open the expansion tank cap to relieve any pressure, close it up tight.
- start the engine, rev it up to 3K RPMs a few times, then shut it off.
- crack the expansion tank cap open again and listen for a pressure release.
If there is pressure, you have a blown head gasket.
Old 11-02-2013, 03:19 AM   #6
yeee46
My Ride: 330I S54
first of all, pressure test your cooling system and radiator reservoir cap and then report back. like what jfoj said, these thermostats can fault open, or just fault in general. it sometimes won't throw a check engine light but it will be stored in the dme.
but first step is to pressure test ur system and cap.
if your scared its a blown head gasket, looks for signs of mixture (oil and coolant) either on the dipstick or on the bottom of the radiator cap, and compression/leak down test it.
report back, i'm sure guys on here are curious.
good luck.
yeee46 is offline   Reply With Quote
Old 11-02-2013, 09:21 AM   #7
CSP
My Ride: m54
if it were a head gasket or water pupmp it would overheat while he was driving as well. looks like it's only at idle. I say fan clutch.
CSP is offline   Reply With Quote
Old 11-03-2013, 01:58 PM   #8
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Or the aux fan isn't coming on...
Old 11-03-2013, 02:52 PM   #9
Shockingtaco
I assume the mechanical fan is the one that's belt driven or the one infront of the engine? I just want to make sure I don't mess something up, bit of a noob. :/
Old 11-03-2013, 02:54 PM   #10
Shockingtaco
good luck.
So even though I just replaced the thermostat it can fault to open?
Old 11-03-2013, 03:18 PM   #11
NumbaOneNewb
My Ride: 2003 330CI Silver
I don't think it's faulting to open especially if you got an OE or oem one. Perhaps the fault lies in components of your cooling system that has yet to be replaced.
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.
Old 11-03-2013, 03:52 PM   #12
Shockingtaco
Also, to add, I recently noticed before the overheating problem, that my car heater would only heat the vehicle for a few minutes, then the cabin air would turn into ambient cool air.... Could this play a major role in deciding what the problem is? Thanks for the help
Old 11-03-2013, 03:58 PM   #13
Stinger9
My Ride: '04 330Ci
Study bleeding harder and bleed your system a few times.
Cool air from heater is classic bleeding done wrong.
Old 11-03-2013, 04:11 PM   #14
Shockingtaco
Well in this event, I will have the system bled and report back, hopefully this fixes the issue... My main question is, if the bleeding was done wrong by my mechanic in the first place how did I last this long with out overheating problems? Could this mean he only bled the system 1 time instead of 2 or 3?
Old 11-03-2013, 04:12 PM   #15
Arnezie
My Ride: 04 325XI
Yes
Arnezie is offline   Reply With Quote
Old 11-03-2013, 05:07 PM   #16
Stinger9
My Ride: '04 330Ci
Yes, therefore achieved marginal performance.
Although my dealer gets it right with only one bleed. They change the coolant and give me the car right away. Drive it away with never a problem. Wonder how they can do it and we can't.
Old 11-03-2013, 05:12 PM   #17
NumbaOneNewb
I only so it once myself and get it right the first time. Key things to take note is sitting the climate control to correct settings, the center vents with the rolling knob on the 3 red dot, bleeder screw open (I tend I open it up as much as I can short of it coming of), and pour slowly with a funnel in the mouth. If your cooling system is strong you can be lazy and not siphon excess coolant out, however if your system is old, I'd recommend siphoning out extra coolant to reduce stress and pressure on the system
Old 11-03-2013, 05:21 PM   #18
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Yes, mechanical fan is belt driven and not electric.
Old 11-03-2013, 05:38 PM   #19
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Could also be air being pushed into the cooling system causing air pockets. Check for a bad head gasket.
coolant, idle, over heat, radiator, water temperature
