318ci from Romania - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Old 02-13-2018, 09:19 AM   #41
lllRazorlll
My Ride: Accord Coupe
You have a license plate bulb out.
Also, is there any coincidence that the plate says CSL?
lllRazorlll is offline   Reply With Quote
Old 02-13-2018, 10:50 AM   #42
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
It's a specific number plate that I ordered, so MS stands for Mures (the county where the car is registered) 32 stands for 3.2 liters and CSL for Coupe Sports Lightweight.
PS: I've dreamt to have an e46 coupe non facelift and for it to have this number plate
tradov22 is offline   Reply With Quote
Old 03-01-2018, 03:16 AM   #43
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
Last night I changed the halogen headlight for a pair of OEM xenon headlights (my car had the wiring loom ready for xenon). But there's a catch, I used sedan headlights and changed the following: cover glass, interior trim and cover strip thus converting them to coupe headlights.
ID:	735290   Click image for larger version
ID:	735292   Click image for larger version
ID:	735294   Click image for larger version
ID:	735298   Click image for larger version
Old 03-01-2018, 10:52 AM   #44
lllRazorlll
Very nice. The headlights are interchangeable minus those parts you mentioned.
Old 03-02-2018, 03:55 AM   #45
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
yes they are. But I can only confirm that you can do that for Sedan Facelift and Couper non Face Lift.
Also, since the headlights are from a RHD car i will be changing the projectors as well. Also I will be changing the lenses on my headlights since they are pretty shot.
Old 04-28-2018, 07:57 AM   #46
thecos
My Ride: 2002 325i Sedan
Great progress. I would also get rid of that factory headunit and replace it with an Android one like this:
https://www.ebay.com/itm/Camera-GA91...rd!11358!US!-1
or
https://www.ebay.com/itm/9-Android-6...AAAOSwcgNZMUQ3
It's been one of the best modifications I've made for every day driving. If you decide one one, make sure it has at least 2GB of RAM.
thecos is offline   Reply With Quote
Old 08-12-2019, 07:52 AM   #47
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
Hello, long time no post. a month ago or so, I finished the engine swap (N42B20 to M54B25). The reason for choosing the B25 ar purely due to the homologation process in Romania (pain in the ass).
So in total the following parts needed to be changed: Engine, gearbox, driveshaft, hydro lines (needed custom lines since the donor car was RHD). I kept the original brakes since the car had 330i brakes for the past 2 years.
Electronics: in order to have the alternator working, a separate 12V switched line needed to be added and also another cable for the climate compressor.
I kept the original ignition barrel and I made myself 2 new keys.
Old 08-12-2019, 07:57 AM   #48
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
here are a few photos during the engine swap
ID:	781485Click image for larger version
ID:	781487Click image for larger version
ID:	781491Click image for larger version
ID:	781493Click image for larger version
Old 08-12-2019, 08:01 AM   #49
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
After the engine swap was completed I needed to change the following: valve cover seal and bolts, PCV valve and the hoses associated, MAF sensor (i chose Pierburg), vacuum lines and Denso Spark plugs. Next week I will be doing the O2 Pilot Mod.
Old 08-12-2019, 10:58 AM   #50
thecos
I hope you changed out the CCV, Oil Housing Gasket and all the other maintenance stuff that's on the side of the motor. So much easier to do it with the engine out of the car.
Old 08-12-2019, 01:27 PM   #51
Antti
My Ride: 330CI / 316 1.8i
Year: 2005
Model: 330CI M-Sport II
Transmission: Automatic
How difficult it was for electrics?
I have been considering after some beers consumed if i change m54b30 or m54b25 for my winter beater 316i
Do you want to do another one there
BMW E46 330CI M-Sport II 2005 Individual Black Sapphire metallic /Showroom
BMW E46 316 1.8i Sport 2005 Mysticblau metallic /Showroom
Renault Clio RS197 2007 Ultra Red
Antti is offline   Reply With Quote
Old 08-13-2019, 05:25 AM   #52
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
sadly no. The only seal that I've changed is the valve cover gasket and the seals around the bolts. The CCV valve including the hoses will be changed next week. I also need to change the crank sensor since I keep getting oil inside one of the ECU connectors.
The engine was very clean when I took it out of the donor car. Sadly I did not have the necessary time to do a proper engine inspection since the whole swap was done in one day...
Old 08-13-2019, 05:26 AM   #53
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
everything should be plug and play M54B22 B25 and B30 use the same ECU and wiring loom. Does your car have ASC or DSC?
Old 01-14-2020, 04:42 PM   #54
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
2020 update:
M Clubsport door seals
Facelift trunk lid
New OEM headlight lenses
TV module retrofitted, Rain and light sensor and oem microphone
Power Flex polly bushes have been order
started on the rear axle refurbishment
Old 01-15-2020, 06:13 AM   #55
tradov22
My Ride: 325ci
Year: 2002
Model: coupe
Transmission: 6MT
and a few photos from the past few months
ID:	791727   Click image for larger version
ID:	791729   Click image for larger version
ID:	791731   Click image for larger version
ID:	791735   Click image for larger version
ID:	791737   Click image for larger version
#318ci, #clujnapoca, #romania
