mason x-brace instead of subframe reinforcement plates? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 06-29-2019, 08:59 AM   #1
wfx32
My Ride: AWD
Model: 330XI 08/2004
Transmission: auto
has anyone tried this mason x-brace alternative to the weld-in subframe reinforcement plates ?
wfx32 is offline   Reply With Quote
Old 06-29-2019, 09:05 AM   #2
wfx32
My Ride: AWD
Transmission: auto
BMW E46 X-Brace Rear Suspension Sub-frame Support
Designed to correct the factory defect on the suspension hard points. This support bolts on without welding. No removal of the fuel tank or suspension is necessary.
Old 06-29-2019, 10:24 AM   #3
wfx32
My Ride: AWD
Transmission: auto
or these powerflex subframe bushing inserts are a better preventative measure?
https://www.powerflexusa.com/shop/pr...ng-insert-3626
https://www.powerflexusa.com/shop/pr...g-inserts-3747
ID:	778597   Click image for larger version
ID:	778599   Click image for larger version
Last edited by wfx32; 06-29-2019 at 12:39 PM. Reason: front and rear bushing inserts are different
Sponsored Links
Advertisement
Old 07-01-2019, 09:39 PM   #4
wfx32
My Ride: AWD
Transmission: auto
closest DIY i could find for the subframe bushing inserts was on an E39.. suggestions on how the E46 install would be any different?
Old 07-01-2019, 11:02 PM   #5
jmo69
My Ride: 03 325xi 98 328is
Actually the xi doesn't have as many subframe issues as the RWD cars, less power to the rear.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 07-02-2019, 12:12 AM   #6
wfx32
My Ride: AWD
Transmission: auto
Originally Posted by avdi.vide.tace View Post
I think this would be most beneficial after addressing all cracks properly. You cannot determine the extent of damage to the many weld spots that go defective, because they are often covered over with the seam sealer (among dirt, debris, et al).
Redish Motorsport has countless videos of the proper inspection, repair, and reinforcement process; I've seen too many E46 M3 owners skip over proper inspection and repair of ALL the damage before even thinking about installing reinforcement plates.
This is great for those that have their subframe repaired already, as it indeed will assist, with the reinforcement plates, to prevent further damage from occurring once it is all repaired.
thanks yes i have heard this is more of a RWD m3 and drifter issue .. but the reason i am worried is that the chassis subframe tearing problem has been known to occur on all e46 models ..
i never had a rear differential issue with the 2004 and i am the original owner.. but the previous owner of the 2005 (with redesigned rear diff) replaced both rear diff in 2017.03, i had further leaks and replaced right rear diff in 2019.01, also diff mount bushings were splitting badly which is a precursor to the tearing.. so i replaced with armstrong poly rear diff mounts.
mechanic i trust says go with the powerflex bushing inserts as a preventative measure. youtube says structural foam (bmw official solution) or weld-in reinforcement plates (turner or bimmerworld) are both patch fixes which may not actually solve the problem. so i'm thinking of having the chassis inspected for the cracks and then install the mason x-brace.
Last edited by wfx32; 07-02-2019 at 12:35 AM. Reason: reference previous x brace thread
Old 07-03-2019, 12:23 AM   #7
wfx32
My Ride: AWD
Transmission: auto
http://www.redish-motorsport.com/E46...forcement.html
http://www.redish-motorsport.com/BMW...eckReport.html
some scary videos there of the weld defects. he has an interesting process to cut into the chassis to see the cracks and then punch/drill to stop the cracks from spreading.
i guess this repair would require some professional skill. i'm not sure who would be prepared to take on the work here. it would be a bit difficult to bring my car to his shop in Bristol UK.
Old 07-06-2019, 06:53 PM   #8
wfx32
My Ride: AWD
Transmission: auto
edit .. wrong thread .. again
Old 08-19-2019, 11:13 PM   #9
jmo69
I don't understand what you mean by "replaced right rear diff" I've only got one rear diff and it's pretty much in the center.
1998 328is 5sp
Old 08-19-2019, 11:41 PM   #10
wfx32
My Ride: AWD
Transmission: auto
05 rear diff has two halves. 04 was a simpler design. i will take a couple of photos when i get the 05 back.. hopefully this week.
Old 09-01-2019, 07:25 AM   #11
Zaknin
My Ride: 2002 330xi
Year: 2002
Model: 330xi
Transmission: A5S390R
Here is the video of x-brace installation, author said that only nuisance is that bracing is squeaky on hard bumps\potholes, audible without music in car, I don't think I would be happy with something like this for daily, but for weekend toy - why not.
2002 330xi Klankenberg
Drive 2 profile
Zaknin is offline   Reply With Quote
Old 09-01-2019, 08:28 AM   #12
wfx32
My Ride: AWD
Transmission: auto
Originally Posted by fixnit4u View Post
Immediately I could tell a difference after the install as the rear end is definitely planted and more secure now. I have rubber diff and subframe bushings because this is my daily driver and I'm happy that although the body is much more rigid, this didn't cause any issues with harsh handling or other negative driving dynamics. I read somewhere that someone had issues with squeaking noises, but in my case it's completely quiet and I think that could've been due to improper installation or other issues with that person's car.
Also, I wanted to attach a few photos because the other installs I've seen look either ghetto or half-assed.
-jake
i called mason a few months ago to discuss this. squeaking may have just been hanís install.
