[MS4X] Siemens MS43 Community Patchlist for Tuner Pro - Page 9 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-04-2019, 03:22 PM   #161
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
Transmission: 5 spd manual
Originally Posted by andyz28 View Post
ok, so the only thing i need to do is flash the file "E46 M54B22 EU4 LHD" to my ecu using the ms4x flasher without patching the ews or checksum bypass? i want the launch control function, so i need to activate the launch control with the patch but without moving nothing more?
thanks you in advance
you apply the needed patch only. Every one is mandatory ,not a must. if your car does not start after ews sync ,then try to use ultimo for correction (against your actual working full file) then flash with superfaster ms4x flasher,but disable chk correction under settings.
scorpionreptyle is offline   Reply With Quote
Old 08-04-2019, 05:47 PM   #162
danius375
My Ride: BMW 330ci (E46)
Originally Posted by sda2 View Post
Is there anyone willing to test a new, true Alpha-N patch before we launch it into the patchlist?
More than happy to try it out on a pretty much standard M54B30.
danius375 is offline   Reply With Quote
Old 08-11-2019, 02:50 PM   #163
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
nothing new here ? hows the testing going ? ignition cut will be ready ,it requires a license ?
Old 08-11-2019, 03:07 PM   #164
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
I’d try but I don’t know how to carry over my turbo tune from v56
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 08-14-2019, 12:10 PM   #165
Skdsh
My Ride: 330I
Who do I have to give my money for the ignition cut. I am about destroy my harness to install a fuel and spark controller.
Skdsh is offline   Reply With Quote
Old 08-15-2019, 09:19 AM   #166
danius375
Same here!
Old 08-15-2019, 11:27 AM   #167
cwarel
My Ride: 330ci coupe
Just insalled wot box 0 flames , only launch control and no lift shift ( i ahve a turbo )
cwarel is offline   Reply With Quote
Old 08-16-2019, 12:37 AM   #168
Harry_de_best
My Ride: E46 330i
Year: 2002
Model: 330i M Sport
Transmission: Manual 5spd
2002 E46 330i EU here. ECU number 5WK90015
MS430069 RHD EU2 full flash file with Checksum bypass, LC, M3 Cluster, Extended DS2 patches applied results in error 100, car only cranks doesn't start. UIF VIN and ISN have been copied over as well - no difference.
MS430069 RHD EU4 full flash with above patches results in the same, car cranks doesn't start.
Sometimes EWS errors came up, re-synced EWS still same issue. TPS error (112?) comes up even when the checksum bypass is patched (lc_swi_cal_mon_cks = 165).
Various flashing combinations tried:
Checksum corrected via new checksum tool posted in this thread earlier + MS4X flasher v1.02 with checksum correction disabled -> car cranks doesn't start
Verified all full and partial reads - all the patches carried over, but only cranks. I'have tried cranking for an extended time as tried by scorpion, however nothing happens.
Patched full file + MS4X flasher v1.02 with checksum correction enabled -> car cranks doesn't start
MS430069 RHD EU2 full flash file with M3 Cluster, Extended DS2 patches applied starts up fine no problems - flashed normally with MS4X checksum correction enabled. Didn't need to re-sync EWS or patch UIF VIN or ISN.
Hope this helps... LC did work in this car on V56 a while ago.
RE sda2: Happy to test Alpha-n, stock apart from catless headers and exhaust. EU vehicle.
Harry_de_best is offline   Reply With Quote
Old 08-17-2019, 05:26 PM   #169
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
use your working version as an original file when you apply correction using ultimo. mod any v69 you want with any options then use ultimo for correction against your working file.Dont forget to disable chk correction in ms4x flasher options before flashing procedure,otherwise ultimo corrections will be overwrited. i think that latest ver of the ms4x flasher works to , i`ll double check tomorrow. One above other ,ultimo is a workaround as long as you have a working version of v69.
Old 08-18-2019, 12:21 AM   #170
Harry_de_best
My Ride: E46 330i
Year: 2002
Model: 330i M Sport
Just tried, ultimo corrected vs the new checksum tool resulted in the same file. Still only cranks, cranked for a while too. Don't think its the checksums, my temp needle doesn't go into the red.
Old 08-19-2019, 07:06 AM   #171
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
assure yourself that you have good battery amps ,it will crank but not start without proper amps. Charge battery to full before cranking again.
Old 08-19-2019, 06:09 PM   #172
sda2
My Ride: BMW E46 330i Touring
MS4X flasher calculates the checksums the same way the ECUs do, it will work with every softwareversion available. There is no need to disable the correction there.
..:: Visit
- the ultimate Siemens MS wiki ::..
sda2 is offline   Reply With Quote
Old 08-20-2019, 06:42 AM   #173
Harry_de_best
My Ride: E46 330i
Year: 2002
Model: 330i M Sport
The car is my daily, so after the file with all the patches didn't work I simply flashed in the version with only the M3 cluster and extended DS2 logging patched. Car runs fine and start no problems, only when LC is patched does it not start.
Old 08-22-2019, 09:46 AM   #174
bernardo774
My Ride: E46 328 B30 Swap
Year: 1999
Model: 328
Using the MS4X with sucsess. Great Tool!
i swap MS42 to MS43.
read the ISN from MS42, wrote to 69 and do a full flash with MS4X. i keep the EWS
the first start delay 4 or 5 engines turns, and POWER!
i will try the LC and post a reply
ATENTION: aways use external power suply 20amp.
Tks for the Tean!
bernardo774 is offline   Reply With Quote
Old 08-22-2019, 09:47 AM   #175
bernardo774
Year: 1999
Model: 328
Double
Old 08-22-2019, 09:54 AM   #176
cwarel
Tks for the Tean!
damn 20amp quite a lot, I use 0.5mha usb adapter form laptop does the job just fine.
Old 09-21-2019, 08:29 AM   #177
Iliyasuper
My Ride: 316 with M54b30
Some new info in wiki regarding MAF RS4
Note: The MS4x ECUs do NOT convert the ADC return value into voltage, but keep the digital 8bit value and convert it directly into airmass.
What does it mean? Is required additional action, except of replacing maf table and patch by patch list?
ٍSo, what is required for use MAF RS4 ?
- Connect, included additional 5V wire
- Apply MAF patch with patchlist
- Replace MAF table
That is all? Correct?
Iliyasuper is offline   Reply With Quote
Old 10-04-2019, 04:03 PM   #178
dargorbr
My Ride: Civic
Hello everyone,
Im a bit confused, what do I need to do in order to flash the 69 version?
Just do a full flash of the 512kb files on wiki?
The car has working ews and just had partial flashes until now
dargorbr is offline   Reply With Quote
Old 10-04-2019, 04:03 PM   #179
dargorbr
My Ride: Civic
Hello everyone,
Old 10-05-2019, 06:39 PM   #180
danius375
Originally Posted by dargorbr View Post
Hello everyone,
Just apply the mods to the 512kb file for your engine using the community patch and full flash it onto your ECU using Siemens MSS4x or MS4x Flash Tool. If you want launch control to work, make sure you disable the MON checksum correction by setting lc_swi_cal_mon_cks to 165.
