BMW e46 344ci M62 - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 03-26-2016, 06:03 PM   #21
ShakotanRon
My Ride: 2000 323i
When you say that the subframe needs to be spaced 30mm you are speaking of spacing it downwards? What reason is this for?
You are effecting roll center negatively by doing this. And I don't want to do that
ShakotanRon is offline   Reply With Quote
Old 04-10-2016, 12:56 PM   #22
DarkJoker
My Ride: 01 330ci
I'm assuming because he did not want to spend $3k+ on a dry sump system.
The oil pan will not clear the subframe w/o modification
DarkJoker is offline   Reply With Quote
Old 04-10-2016, 01:02 PM   #23
ShakotanRon
My Ride: 2000 323i
Ok. I would rather modify the subframe (don't know if that is a real world possibility in the case.)
Just saying that if some cutting and welding Wil make it clear then I would rather do that.
Sponsored Links
Advertisement
Old 04-10-2016, 01:02 PM   #24
ShakotanRon
My Ride: 2000 323i
I am sure the oil-pan is a structural part of the engine on these engines. Am I right?
Old 12-23-2016, 06:48 PM   #25
MAXixt
My Ride: e46 335ci
Originally Posted by Taper View Post
Is possible to modify the oil pan to save front sway bar?
E30 subframe with sway bar.
MAXixt is offline   Reply With Quote
Old 12-23-2016, 06:48 PM   #26
MAXixt
My Ride: e46 335ci
Soon will be another V8 swap, but this time with M62 TU engine .
Old 04-08-2017, 05:21 AM   #27
YoitsTmac
My Ride: 01 330Ci "Mia"
aren;t all the E39 and E46 computers the same? Can't we just, as you say, look at both diagrams and plug and play? I feel transferring over E39 computers would need to inaccurate speed sensing with different bearings/hubs and such.
BMWCCA GGC: 530872
YoitsTmac is offline   Reply With Quote
Old 11-26-2017, 02:27 PM   #28
MAXixt
My Ride: e46 335ci
Not to make another similar topic I decided to post here. Another V8 M62 swap, but Vanos engine this time , Tu engine, because this time we want to make allsistem work. Car was 320ci 2.2 from factory, we changed rear axel to 3.0, all brakes around from 330, hight and hardnes adjustable coil overs, 3/38 188 diff, gearbox from 3.0 m54 6 speed with rewelded bell,engine m62b44TU from x5, fully redisigned oil pan and pump, custom engine mounts,custom driveshaft, z4m shifter,oem 330 6 speed gearbox mountings.
Old 11-26-2017, 02:28 PM   #29
MAXixt
My Ride: e46 335ci
Some pics of course
ID:	704441   Click image for larger version
ID:	704449   Click image for larger version
ID:	704457   Click image for larger version
Old 11-26-2017, 02:32 PM   #30
MAXixt
My Ride: e46 335ci
and some more
ID:	704481   Click image for larger version
ID:	704489   Click image for larger version
ID:	704497   Click image for larger version
ID:	704513   Click image for larger version
Old 11-26-2017, 02:54 PM   #31
DarkJoker
My Ride: 01 330ci
That's awesome.
Sent from my LG-LS998 using Tapatalk
Old 11-27-2017, 03:37 PM   #32
MAXixt
My Ride: e46 335ci
Thanks, our next V8 project will be e86 with s65 turbo.
Old 12-26-2018, 02:14 PM   #33
MAXixt
My Ride: e46 335ci
Last pic of swap
Old 08-10-2019, 09:55 PM   #34
bmwfanaticftw
Did you use any electrical components from a e39 in your 320ci build? The battery, computer, ecu, the dash cluster and etc.
bmwfanaticftw is offline   Reply With Quote
