E46 Complete Suspension Torque Specs - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 06-03-2016, 10:44 AM   #21
jazzbass
My Ride: 99 328i; 06 330i
Originally Posted by luke949 View Post
Sorry for a cruddy picture, here is a better one. This is the 2 front subframe bolts to the chassis.
I think this is the correct spec - 90 Nm
Chris M
1999 BMW 328i
2006 BMW 330i
1985 Porsche 911
jazzbass is offline   Reply With Quote
Old 06-10-2017, 05:20 PM   #22
WilloCO
My Ride: '05 330xi 6 speed
Handy. This was helpful today.
I bedded my pads when I switched from ceramic to my PDF-Z pads. They actually caught fire during bed in.
05 330xi 6 speed
RIP: 86 e30 w/E36 M3 suspension build
WilloCO is offline   Reply With Quote
Old 06-15-2017, 09:21 AM   #23
Hector45
My Ride: 2002 OB 330i
Glad to hear it how did the job go?
Hector45 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-07-2017, 08:10 PM   #24
dan_roh
My Ride: BMW 320i Touring
Great thread i'm putting my front frame pieces back together and i was looking for torque specs
It will spare me a lot of time !
dan_roh is offline   Reply With Quote
Old 05-24-2019, 11:27 AM   #25
TopCityBMW
My Ride: 330xi
A helpful friend loosened and removed the 6 nuts/bolts mentioned by OP that were holding the rear aluminum subframe / carrier on my xi. Now it's tipped forward and dropped maybe an inch...binding up on the two studs that go thru the bushing...it appears.
I have a jack underneath that lift point to take weight off. However it lifts the whole car.
Any thoughts on how to get the subframe back into place?
I am thinking lifting slightly from the two rear jack points and the subframe jack point simultaneously.
TopCityBMW is offline   Reply With Quote
Old 05-24-2019, 04:19 PM   #26
Hector45
Are you trying to lower the whole rear assembly?
Old 05-24-2019, 04:22 PM   #27
TopCityBMW
My Ride: 330xi
No. Only the two front are loose. I want to get the whole thing back up against the frame. Unfortunately it appears tilted some downward and so the bushings are bound on the studs.
Old 05-24-2019, 04:48 PM   #28
Hector45
No. Only the two front are loose. I want to get the whole thing back up against the frame. Unfortunately it appears tutored some and the studs are bushings are bound on the studs.
Yeah that may be tough, i lowered it as one unit but put it back on in pieces. Lowering it was tricky because the tolerance of the stud going through the bushing is pretty tight so any off axis force will cause it to instantly bind. The whole assembly is off axis to those studs.
I would recommend getting two jacks like you said, support the front and back and try to raise them at the same time slowly to get them back up. I basically had to do the same thing in reverse when lowering it.
