Tuning for BMS46 - Page 5 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-13-2018, 02:03 AM   #81
TheDevil666
My Ride: e46 BMW 318i
Year: 2000
Model: 318 i
Transmission: MT
Tuning for BMS46
I Need The hex adress for the RPM limiter i dont use winOLS , i have Ecm Titanium !
And im interresting for torque in this Bms 46 ?! I Hope Is in ????
Gesendet von iPhone mit Tapatalk
TheDevil666 is offline   Reply With Quote
Old 07-16-2018, 05:41 PM   #82
TheDevil666
Year: 2000
Model: 318 i
Transmission: MT
Originally Posted by TheDevil666 View Post
00FFFA set to 31 from 68
00FFFB set to 66 from E8
This is deactivate lambda 2 behind the Catalyst to silencer
Kind Regards
this is the Adress from the file in my BMS46 318i E46
my file is read withh Kess and have 256 kb!!!!! not 32 kb !!!!!!
Old 07-16-2018, 05:51 PM   #83
TheDevil666
Year: 2000
Model: 318 i
Transmission: MT
So here is the Tune file and Orginal file from my BMS46 318i E46 118CV
Kind Regards
File Type: pdf BMW 318I E46 BJ 2000( TUNE_VERSION_#1 ).pdf (256.0 KB, 113 views)
Sponsored Links
Advertisement
Old 07-17-2018, 11:17 AM   #84
daniel_f.
My Ride: 330iC
What hardware is used at that ecu? What flash? What processor? Seems like their is a different memory which contains the boot section. We would need that for a disassembly.
No further development on MS4x from me.
Old 07-17-2018, 05:30 PM   #85
Rhyno92
My Ride: z3 1.9 kompressor
Transmission: MT
Daniel, the processor is ZC439505MFT20.(MC68336)
The flash is AM29F200AB (psop44).
I remeber that on the board there is a eprom(8pin) but i don't know which one.
Rhyno92 is offline   Reply With Quote
Old 07-18-2018, 05:10 PM   #86
Rhyno92
Transmission: MT
No, i'm sorry. Now i'm sure that there isn't an eprom on board. Only the flash and processor can give "information"
Old 07-19-2018, 12:22 AM   #87
Rhyno92
Transmission: MT
Photo of board
ID:	749510   Click image for larger version
Old 07-20-2018, 08:17 PM   #88
Rhyno92
Transmission: MT
Kind Regards
i see you files.
4/5 points of advance spark plug. (x0.75 = 3)
5 points on fuel base map.
something on 0085C0 but i don't know what is it.
And on FFFA and FFFb i think it is like a checksum.
can you give us other information please???
do you try on road your car? do you notice any goodnes thing?
where is relapsing shutdown?
Old 07-21-2018, 05:08 AM   #89
TheDevil666
Year: 2000
Model: 318 i
Transmission: MT
i see you files.
This is to deactivate lambda 2
0085C2 ---> 0085C9
and
0085CD ---> 0085CE
This is the adress to relapsing shutdown
0085CA ---> 0085CB
This is the adress for ASC pemanent disable ( but light always ON , can be deletet with NCS-Experttools from BMW)
All Adress from my Files !! (256kb)
where is in my file the RPM Limiter ????
what hex Adress pls !
Kind Regards
Peter alias TheDevil666
Old 07-21-2018, 05:44 AM   #90
Rhyno92
Transmission: MT
I don't understand how work relapsing shoutdown. How 4 bit can make extrafuel?? Maybe you disabile cut-off strategy? Or what?
FFFa and FFFb are out of normal partial Read. Do you know other information of hide byte?
Old 07-30-2018, 04:28 PM   #91
Rhyno92
Transmission: MT
Please guys! I don't want this thread dead again for a long time! Please help me to go to the Next step.
Old 07-30-2018, 05:17 PM   #92
daniel_f.
My Ride: 330iC
Next step is disassembly of the flash. Unfortunally there is bootcode missing if i 'm not totally wrong. The first few Bytes hint to the reset handler usually.
Old 07-30-2018, 05:30 PM   #93
Rhyno92
Transmission: MT
What we need? What we can do?
Old 07-30-2018, 05:36 PM   #94
walopower
My Ride: BMW e39 525iA
Originally Posted by FritzP View Post
I have not tested the FGTech BDM, but I will not be surprised if it will work on this ecu beside the MSS52/54.
1- BKPT/DSCLK
2-VSS
3-FREEZE
4-RESET
5-IFETCH/DSI
6-BERR
7-DSO/IPIPE
8-DS
9-VSS
10-VCC
FGTech pins are:
1-VFLS0
2-SPRESET
3-GND
4-DSCK
5-GND
6-VFLS1
7-HRESET
8-DSDI
9-VDD SENSE
10-DSDO
Can you help identify what pins I should connect, like:
BMS46/FGTech
4/7
walopower is offline   Reply With Quote
Old 07-30-2018, 05:45 PM   #95
Rhyno92
Transmission: MT
I got fgtech and an used bms46 for try a lot of things. If you help me to connect to fgtech or bdm100 i can Read processor or other important information.
Old 07-30-2018, 05:48 PM   #96
Rhyno92
Transmission: MT
Can you help walopower to identify every pin?
Old 08-12-2018, 01:37 PM   #97
Rhyno92
Transmission: MT
Finally i find the time to try some things.
I try the solution for relapsing shoutdown. It work, but it disabile cut-off, so the car use much more fuel, and the idle is a bit strange. Se need
Old 09-28-2018, 08:50 AM   #98
silee46
My Ride: m42head-m43-m47crank
Year: 2001
Model: e46 318i
Transmission: manual 6speed (330i)
Hi,
Do anyone knows what means maps in partial read (32kB) with adreses: 01B82, 01C5E, 029B9
I am curious because in stage 1 remaped file it is changed by average +5.......
silee46 is offline   Reply With Quote
Old 09-28-2018, 08:55 AM   #99
silee46
Year: 2001
Model: e46 318i
Here is stock and remaped file just for compare.
I need to know what means adresses:
01B82, 01C5E, 029B9
Old 03-09-2019, 10:36 AM   #100
MathieuTaelman
My Ride: Bmw e46 M43
Did you work on this ECU more? This forum is my only hope now haha I have a couple of tuned maps from my car but I didn't notice improvements. I am using WINOLS but I can't find what is what. Can we work on this together more? can I contact you on a different platform?
Thanks!
MathieuTaelman is offline   Reply With Quote
