Tuning for BMS46 - Page 6 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-11-2019, 06:09 AM   #101
silee46
My Ride: m42head-m43-m47crank
Year: 2001
Model: e46 318i
Transmission: manual 6speed (330i)
Hi,
Yes we can work together, I will send you private massage.
silee46 is offline   Reply With Quote
Old 03-11-2019, 02:30 PM   #102
MathieuTaelman
My Ride: Bmw e46 M43
My idle is strange after I changed the values for relapsing shutdown. If I change them like in your map my idle stays at 1500rpm en when i give it a little gas it drops again.
MathieuTaelman is offline   Reply With Quote
Old 03-25-2019, 04:52 PM   #103
TheDevil666
My Ride: e46 BMW 318i
Year: 2000
Model: 318 i
Transmission: MT
Bms 46
here is my last file what im do for my 318i !
and when i start my car i wait 5 min and let it run warm !
My feeling tells me that my BMW 318i is much better in acceleration than the tuning file of my tuner!
my bordmonitor shows me at 8,6l -> 100km
read with Kess and edited with titanium by me!
TheDevil666 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 03-26-2019, 03:02 AM   #104
MathieuTaelman
What did you all change? Do you have weird idle as I saw that you did a relapsing shutdown?
Old 03-26-2019, 04:44 PM   #105
TheDevil666
Year: 2000
Model: 318 i
Transmission: MT
My copletly Oginal File before Tuning it
Old 03-26-2019, 04:57 PM   #106
TheDevil666
Year: 2000
Model: 318 i
Transmission: MT
I activated my second O2 Sensor !
File Type: pdf 22.10.18 BM-K113 O2Sensor Activated.pdf (256.0 KB, 41 views)
Old 03-27-2019, 06:52 AM   #107
TheDevil666
Year: 2000
Model: 318 i
Transmission: MT
My first tune file for my 318i made by Tuner
Old 03-29-2019, 12:42 PM   #108
CrazyTo
My Ride: E46 318Ci
Year: 2000
Model: Coupe
Transmission: Manual
I`m with M43B19 318 on 00`E46 Coupe. So if i can help with something, will try. I have INPA cable and laptop with WIN xp.
CrazyTo is offline   Reply With Quote
Old 04-12-2019, 04:09 PM   #109
anziz
My Ride: 300
Is it possible to turn ews off?
What is the hex adress for ews?
I have had couple of times ews problems.
anziz is offline   Reply With Quote
Old 04-19-2019, 05:35 AM   #110
MathieuTaelman
Does somebody has the adress to disable secundairy airpump?
Old 04-19-2019, 07:19 AM   #111
CrazyTo
My Ride: E46 318Ci
Year: 2000
Model: Coupe
i`m with EU softwere, disconect the SAP and didnt have CEL. Only error when connect with INPA.
What i need to write that file, and will it be compatibility to mine car?
E46 318Ci M43TU BMS46 EU3 DS1 PN:1-430-940
Thanks!
Old 04-22-2019, 04:59 AM   #112
daniel_f.
My Ride: 330iC
Obviously it depends on the softwareversion.
No further development on MS4x from me.
Old 05-06-2019, 06:06 AM   #113
MathieuTaelman
It is a 1999 318i e46 euro 2. I deleted the sap but i just want the error gone in inpa
Old 06-09-2019, 09:21 AM   #114
CrazyTo
My Ride: E46 318Ci
Year: 2000
Model: Coupe
Upload full read with KESS v2 on my stock ECU.
What does relapsing shutdown do, because there isnt information in the web?
Thanks!
Old 06-28-2019, 06:26 AM   #115
lucinegrescu
BMW e46 318i turbo
Hi
I own a bmw 318i 1998 118cv 8v and put the turbine on it. Below I attached the original file read with kess v2. I'm interested if anyone knows the address of the flow meter (flow / voltage) and the main injection chart because I changed the flowmeter to a larger one and I put larger injectors. Thanks!
lucinegrescu is offline   Reply With Quote
Old 07-27-2019, 05:20 AM   #116
CrazyTo
My Ride: E46 318Ci
Year: 2000
Model: Coupe
Hi! Here is mine tuned file, its changed advance of sparks and fuel map.
I have a question, how much to retard the ignition to make burble when off throttle, and does it can be modded only with the ignition spark map?
I edited it with ECM 1.61, read it with kess.
ps. With that kind of tune there isnt much difference from stock, does i need to turn up the fuel more?
Old 10-20-2019, 12:03 PM   #117
MathieuTaelman
Does someone know where the thermostat map is, I want to run the engine cooler because 105 degrees is to much for me
Old 12-03-2019, 02:52 AM   #118
MathieuTaelman
I found the adress to delete DTC for SAP and function! ***x1f642;
Old 12-03-2019, 02:54 AM   #119
MathieuTaelman
I now have a good mappack for this ecu with factors and offsets. I only want to find max speed in ecu as the bms46 ecu limits the speed to 206kmh. I already found max RPM!
Old 12-05-2019, 06:31 AM   #120
Lambda1
My Ride: E46 330i, E36 328i K
Transmission: MT only! or PDK, DKG
if you got all offsets... and know speed limit... shouldnt be as hard to fine mate...
Lambda1 is offline   Reply With Quote
