Biggest MS43 tuning thread ever! Incl software... - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 32 votes, 4.97 average. Display Modes
Old 10-02-2015, 04:28 PM   #61
daniel_f.
My Ride: 330iC
DTC supression is needed if we do things the ecu doesn´t like, like disconnecting MAF sensor. In case of EU2 tune, this is something that was available for some markets and therefore the switch was configure to set all kind of monitors and stuff to accept for the new hardware.
It should easily work that way, if not just let me know.
Old 10-02-2015, 04:31 PM   #62
tflow
My Ride: 330i
will give it a try.
Thanks !
tflow is offline   Reply With Quote
Old 10-03-2015, 07:32 PM   #63
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
tflow,
The EU2 software for the E46 is the standard factory software used here in Australia. It is very hard to find post-cat sensors fitted here.
I am running a twin 200 cell cat system without any problems with the factory software, no sensor mods or anything.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-04-2015, 02:54 PM   #64
Newbie41
My Ride: E46 320Ci
Danial,
thanks for the help.
Tweaking the injection map is working.
Question.
1) what maps do we tuned for ignition? there is almost 5 ignition maps, would making changes to basic ignition map be enough?
2) how do I incorporate afr readings to BMWlogger? I have a innovate wideband, but I have no idea how to link the afr to the logger.
I am still learning to tune and familiarise with the software. really appreciate all your help.
cheers!!
Newbie41 is offline   Reply With Quote
Old 10-11-2015, 02:31 PM   #65
legoman67
My Ride: Canada
Thank you! I am trying to get the logger to work, but keep getting packet error when i try to connect. It retrieves fault codes fine. Ive flashed both the 512 and 64kb files to the dme doesnt make any difference. Not sure if i need to use that key file in some way?
legoman67 is offline   Reply With Quote
Old 10-11-2015, 04:16 PM   #66
daniel_f.
My Ride: 330iC
Of course you need the key file
Old 10-11-2015, 06:06 PM   #67
legoman67
My Ride: Canada
how do i use it? i couldnt find anything about a key file online.
Old 10-12-2015, 03:23 AM   #68
daniel_f.
My Ride: 330iC
Come on. It can´t be that difficult to watch in instructional youtube video
https://www.youtube.com/watch?t=3&v=g71Bw74vhSQ
Old 10-16-2015, 05:15 PM   #69
jc179
My Ride: 2004-325xi,87-5000TQ
Hi All
Just want to say thanks so much for all the hard work on this! Looks like there's lots of fun to be had.
Apologies if I'm asking in the wrong place, or I need to look into this further:
I'm looking to modify the M54B25 - If I find a MS540056 B25 version, my understanding is I can use the definition file you guys have created, to tweak things like PWM fan control idle speed, etc... But...Is it also possible to flash my current 325 DME to use MS540056 program code with the inpa tool suite (assuming you can figure out the prog number, and right software suite)...?
Is there any option in the def file you've created to disable EWS for M54B25? I would like to add a car starter, and not have the key taped up under my dash where someone can easily find it?
Lastly since my car is a fail-o-matic I'd need to re-code it and add SA205 back?
thanks !
Jonathan
jc179 is offline   Reply With Quote
Old 10-17-2015, 12:05 AM   #70
e46cruiser
My Ride: 02 325i
So what is all needed to tune our ms43's? Tuner pro, BMW logger, and we can read / write the files with galletto? I'm local to Alex and I'm sure he is willing to help me out, actually he is helping me out with my turbo build but I want to tune my daily. I want to remove the sap, rear O2 Sensors and some other stuff that I want to try it myself.
Instagram: @_victorg
e46cruiser is offline   Reply With Quote
Old 10-17-2015, 05:58 AM   #71
daniel_f.
My Ride: 330iC
Originally Posted by jc179 View Post
Hi All
Unfortunally no. Up till today we haven´t found the files needed to flash MS430056 by using WinKFP.
Unfortunally, the ews delete is done in the program section of the file.
There is no simple tune-change to be done to switch ews off. We could implement that, but it wouldn´t help you in the first place.
Your DME will automatically detect if you´re using a manual or an auto gearbox
Right, everything you need is included in the files collection in the google drive. We´ve written some instructions how it needs to be done, they are also included.
Most of what you are after are single byte switches called config switches.
Old 10-18-2015, 11:21 AM   #72
jc179
Thanks for the answers and hard work Daniel. May try running the 325 off a DME flashed with the MS540056 file you gents have and see how it goes.
Edit just noticed in the MS430056 there is a M43B25 file ... that would work for my situation, and has no EWS?
MS430056_M54B25_Logger_EWSsignature_CHK5off.bin
Old 10-19-2015, 01:05 AM   #73
daniel_f.
My Ride: 330iC
Yes, it may be from a BMW E39 if i remember correctly, so some bits may be a bit off, mostly fuel tank size related. You could rule that out by comparing your stock tune file vs a E39 stock tune file.
Old 10-19-2015, 11:55 PM   #74
Newbie41
My Ride: E46 320Ci
Gotta say again. Great Work from Danial_F.
Playing around with decal map.
Old 10-20-2015, 12:48 AM   #75
daniel_f.
My Ride: 330iC
Excellent
Now, i created this thread to help the community grow. For that reason, the only thing i wanna get back is information
If you´re confident the changes you did are working like they should, mention the changes you did At best by before and after screenshots of TunerPro I´d like to try your changes to incorporate Launch-Control
Old 10-20-2015, 01:04 AM   #76
Newbie41
My Ride: E46 320Ci
Here's a screenshot of what I did.
I'm showing the compare difference to a stock map
Old 10-20-2015, 01:23 AM   #77
Newbie41
My Ride: E46 320Ci
would there be a possibility that the software could support live tuning in the future?
Old 10-20-2015, 02:17 AM   #78
daniel_f.
My Ride: 330iC
Excellent
Good news is, we can currently do live tuning. Unfortunally we need some further hardware for this
http://forums.vwvortex.com/showthrea...or-DIY-version
Old 10-20-2015, 03:45 AM   #79
mrbobmicjoe
My Ride: 2001 325i
What is this "decal map" you speak of? Did some research to no avail.
My Boosted M54B25 Build Thread:
mrbobmicjoe is offline   Reply With Quote
Old 10-20-2015, 04:55 AM   #80
Newbie41
My Ride: E46 320Ci
Mrbobmicjoe,
You can see the maps from my screenshot above
