Tune Wiki- How to configure/use Launch Control - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-24-2016, 03:02 AM   #1
daniel_f.
My Ride: 330iC
Hereīs an instruction on how to configure Launch Control (LC) at MS43 and use them:
1. Download the corresponding files in the google drive within the folder "Launch Control". Choose the one that matches your engine displacement. Also download xdf with LC in the description.
2. Flash the file with JMG
3. LC is preconfigured in TunerPro to have a bit of security. If you feel you need to tweak the settings download the tune with Galletto and open it in TunerPro.
4. Under "Special Functions: Launch Control" you can tweak the shown values. Description is available by hovering the mouse over each setting.
5. Save the bin and upload it using Galletto
Using LC
1. Make shure coolant temp is equal or above the treshold
2. Depress the clutch pedal
3. Choose first gear
4. Floor the accelerator pedal! (At least that °PVS matches the treshold!)
5. Engine speed should bounce at choosen rpm setpoint. There may be offset which engine speed bounces, like +/- 200rpm
6. Release clutch pedal while holding accelerator pedal down.
7. Engine speed will be reduced until vehicle speed exceeds choosen treshold
This feature, LC, wonīt make you a professional driver and it wonīt make your car a sports car! If the settings are tweaked to your cars drivetrain and your skills it can definately enhance your cars performance.
Warning:
If the engine does continue to increase rpm even with tweaked settings, you have one of very few weired DMEīs that we need to investigate further!
Check youtube for reference how its intended to work!
Development of LC is still going on so check back for the latest updates available!
Current licensing status:
Security implementation *done*
Implementing Flex Fuel
Old 02-26-2016, 08:37 AM   #2
thecos
My Ride: 2002 325i Sedan
This is cool. I haven't flashed it yet but am willing to try it.
Once you flash LC will it always be active or is there some kind of activation sequence?
thecos is offline   Reply With Quote
Old 02-26-2016, 09:03 AM   #3
daniel_f.
My Ride: 330iC
Its stated above your post
Sponsored Links
Advertisement
Old 02-27-2016, 12:05 PM   #4
matt270avian
Banned User
My Ride: 2002 325XI
I tried this yesterday. Made sure to drive around for about half an hour to ensure everything was up to operating temps, and then stopped in an isolated area. Clutch in, shifted to first and then matted the throttle. The engine caught at the RPM I set (2500) but then kept going past that point. Any ideas?
matt270avian is offline   Reply With Quote
Old 03-11-2016, 01:06 PM   #5
Elvin123
My Ride: 328i
is this not possible on MS42?
Elvin123 is offline   Reply With Quote
Old 03-11-2016, 01:24 PM   #6
daniel_f.
My Ride: 330iC
It may be done when i find a perfectly working solution.
Old 03-11-2016, 10:05 PM   #7
Elvin123
My Ride: 328i
This is exciting
Old 05-17-2016, 11:45 PM   #8
diablorojo
My Ride: Supercharged 330i
Daniel, can you quickly explain what each parameter is (PVS, Launch hysteresis, launch_tco_min, launch_vs_max)
Also, any suggestions for mph?
My boost is early so I'm looking at setting 2800 rpms but a little unclear on the MPH. I have lots of torque so im thinking the single digit mphs would still cause a lot of wheel spin ending the LC too early.
thanks...
Started ESS...ended CUSTOM!
diablorojo is offline   Reply With Quote
Old 05-18-2016, 12:46 AM   #9
daniel_f.
My Ride: 330iC
thanks...
Using LC
1. Make sure coolant temp is equal or above the threshold
4. Floor the accelerator pedal! (At least that °PVS matches the threshold!)
5. Engine speed should bounce at chosen rpm setpoint. There may be offset which engine speed bounces, like +/- 200rpm
7. Engine speed will be reduced until vehicle speed exceeds chosen threshold
From the wiki
Old 05-18-2016, 01:27 AM   #10
diablorojo
Lol, I know how to activate it but to set the parameters I (and those of us less experienced) need to know what each of the tables set.
1. Launch TCO - is this the target cooling temp?
2. Launch RPM MAX - is this the actual set point for the RPM (not to exceed and hold steady at XXXXX)?
3. Launch Hythersis - ?
4. Lauch vs Max - this is the MPH the car must reach before LC disengages?
5. Launch PVS - ?
Old 05-18-2016, 03:55 AM   #11
daniel_f.
My Ride: 330iC
Old 05-18-2016, 11:08 AM   #12
diablorojo
Didnt mean to be confusing. Lol
What is Launch Hythersis and Launch PVS - ?
Old 05-18-2016, 11:29 AM   #13
TerraPhantm
My Ride: M3
The launch hysteresis is basically how much the DME will let the revs drop before bringing them back up to the target. Based on daniel's instructions above, my guess is Launch PVS will be the minimum throttle position necessary to trigger launch control.
Old 05-18-2016, 03:23 PM   #14
AndreBXP
My Ride: 04 M3 6MT, 11 X5 35d
Funny enough, my XDF doesn't have the Launch Hysteresis parameter; is that a new feature?
Maintenance > Mods. Suspension built by Ground Control, tuned by Rob43.
Cars: 2004 M3 6MT Track Toy | 2011 X5 35d Tow Rig | 2004 330xit 6MT ZHP Daily | 2008 328xit Daily
AndreBXP is offline   Reply With Quote
Old 05-18-2016, 04:23 PM   #15
daniel_f.
My Ride: 330iC
Nope, its not used
Old 05-19-2016, 09:12 AM   #16
diablorojo
Thanks guys!!
Old 05-24-2016, 03:00 PM   #17
ReneBMW
My Ride: e36 m3 euro
Cant wait till the m54b30 is in my e36��
How about the no-lift-shift feature, is it working and activated?
ReneBMW is offline   Reply With Quote
Old 05-25-2016, 01:56 AM   #18
sda2
My Ride: BMW E46 330i Touring
Not implemented yet. ISAdelete is on priority right now
sda2 is offline   Reply With Quote
Old 06-30-2016, 03:08 PM   #19
Georg
My Ride: 330 with ms42
nice work guys
Georg is offline   Reply With Quote
Old 10-21-2016, 07:55 PM   #20
44chris
My Ride: E46 320ci
Originally Posted by daniel_f. View Post
Nope, its not used
What does that mean? I also donīt have the hysteris in my xdf.. is there any way how i can get it?
44chris is offline   Reply With Quote
