Siemens MS42 wiki - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-13-2019, 03:02 AM   #61
sda2
My Ride: BMW E46 330i Touring
I had some time at the weekend, would someone be so kind to test 0110C6/C7 EWS delete patch I made?
One of the folowing patches might work. The patch location is 0x283BA in the full binary obviously.
Original 88 90 88 60 8A 0E 02 F0 EA 00
EWS delete try 1: DA 07 C2 58 FE 0E 2E 0F DB 00
EWS delete try 2: DA 07 C8 59 FE 0E 2E 0F DB 00
(explaination here: http://www.romraider.com/forum/viewt...143801#p143801 )
..:: Visit
- the ultimate Siemens MS wiki ::..
sda2 is offline   Reply With Quote
Old 05-13-2019, 12:17 PM   #62
d_cleverzz
My Ride: Turbo 5spd 330cic
Year: 2001
Model: 330CIC
Transmission: 5 Speed Manual
For what vehicle?
Your friendly turbo 330cic,
d_cleverzz
d_cleverzz is offline   Reply With Quote
Old 05-13-2019, 03:14 PM   #63
sda2
Every 0110C6 firmware. Just edit the bytes from 0x283BA and correct checksums.
..:: Visit
Sponsored Links
Advertisement
Old 07-20-2019, 08:56 PM   #64
Alchemy Design
My Ride: 330xi, 328, 525, 335
Year: 2001
Model: 330xi
Transmission: Auto
Can somebody point me in the right direction to disable EWS on my MS42 328?
Thanks =)
Alchemy Design is offline   Reply With Quote
Old 07-21-2019, 01:46 PM   #65
armenh7
My Ride: 2002 325i
Thanks =)
https://www.ms4x.net/index.php?title=Modified_Files
Choose your version, I'm sure the one with the C is newer
armenh7 is online now   Reply With Quote
Old 07-21-2019, 02:46 PM   #66
Alchemy Design
Year: 2001
Model: 330xi
Transmission: Auto
Armenh7, well, now I feel like an idiot. I have no explainable answer as to why I never noticed the MODIFIED FILES link staring me in the face for the past few months while I was referencing the wiki.
Thank you.
Old 10-02-2019, 11:45 AM   #67
Alxj1997
Hello! i'm having a little problem when im trying to edit the "max rpm when missing speed signal". im trying to lower the value due to an re-registration for slow going vehicle, but no matter what im doing, i cant get the ecu to lower the max rpm. to test the function im pulling the fuses to the abs, but i can still rev fully. im trying to lower it to about 1000rpm, i dont know if thats too low or if my problem lies in the ecu programming. im using tunerpro with the xdf supplied at the ms4x wiki. any inputs/ideas what im doing wrong?
and sorry for my bad english :/
Alxj1997 is offline   Reply With Quote
Old 10-03-2019, 02:08 AM   #68
d_cleverzz
Year: 2001
Model: 330CIC
Is it automatic transmission? I think most of the rpm limited parameters are handled by the TCUs for automatic vehicles. Hence why even if you raise the RPM in the tune, the transmission will still shift at stock ďredline.Ē
d_cleverzz
Old 10-03-2019, 07:49 AM   #69
Alxj1997
@d_clevverz nope its a manual. the thing is im trying to decrease the value, thereby if the ecu is missing the speed signal, the vehicle will not rev more then 1000rpm and wont go any faster than 30 km/h in 5th gear
Old 10-03-2019, 11:15 PM   #70
d_cleverzz
Year: 2001
Model: 330CIC
Siemens MS42 wiki
There may lie your problem. 1000rpm is way too low. There may be another parameter somewhere that is preventing you from going that low. Iím not sure though, I donít play too much with ms42. Try setting it so something more reasonable, like 3000 or 4000.
The engine already idles at 700 ish rpm. With a max of 1000, itís not going anywhere.
d_cleverzz
Old 12-16-2019, 01:55 PM   #71
Kyrazh
My Ride: e39
has somebody checked?
i need ews off for m52b20. no such file on wiki
@amp44_piston
Kyrazh is offline   Reply With Quote
Old 12-27-2019, 10:22 AM   #72
mogli_1994
kyrazh
I have verified on 0110C6 that this will disable EWS. Location in hex as sda2 mentioned and make sure to correct checksums. I have compared this across C6, and AD firmwares and they match in location and values to change.
DA07C859FE0E2E0FDB
mogli_1994 is offline   Reply With Quote
Old 01-10-2020, 02:59 AM   #73
d_cleverzz
Year: 2001
Model: 330CIC
Siemens MS42 wiki
Figured Iíd ask. Just looking through ms42 files (I donít work with them often) I noticed they close the disa valve up top. Anyone know why?
Or is this a purposeful restriction...
d_cleverzz
Old 01-10-2020, 04:57 AM   #74
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
Deliberate.
I have had a few people ask about this before. Easy to rectify by copying the MS43 maps.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 01-10-2020, 07:54 AM   #75
d_cleverzz
Year: 2001
Model: 330CIC
Originally Posted by Blu302 View Post
Deliberate.
Exactly my thoughts lol. Thanks for the clarification.
d_cleverzz
Old 02-04-2020, 01:26 PM   #76
d_cleverzz
Year: 2001
Model: 330CIC
So... trying to run MS42 on alpha N. I know for a fact you can run ms43 without a maf.
Ms42 should be able to do the same.
M52tub25.
With maf unplugged, it struggles to start, when it does, it stalls quickly after.
Anyone know what the process is or what can be wrong thatís preventing the car going into maf fail safe mode and using alpha N.
Iím using RomRaider to edit ms42.
d_cleverzz
