ZHP cam specs - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-21-2016, 08:05 AM   #21
rkneeshaw
My Ride: 330i ZHP
Originally Posted by Davew View Post
This may or may not help you to know if the ZHP cam is a 248 or not.
Final photo is at maximum lift, and is at 0.3925 (image 1441)
Cool, I might use this next time I pull the valve cover on my car. Shame, I just replaced the valve cover gasket about two months ago...
Also, .3925 inches is 10mm, which is the lift specs on the Schrick 248 cam, so that makes perfect sense.
Your setup is almost the right setup to measure duration. You'd need your head installed and timed though, and using a degree wheel on the crankshaft you would measure crankshaft rotation starting from when your dial indicator showed .050" through to when it came back down to .050", and that is your duration measurement. I may end up doing this on my car.
Also, as someone who has purchased TS2 and the TS2+ upgrade from ESS, I didn't notice and difference in any of the vanos settings between the two tune files. Just an interesting note to consider
That is what I was suspecting, very good info!
2003 BMW 330i ZHP
ESS Twin Screw Stage 2+ - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - Hawk Performance
Build thread:
Wheelwell:
Fuelly:
rkneeshaw is offline   Reply With Quote
Old 07-21-2016, 12:30 PM   #22
dbarton62
My Ride: 04Z4R VF 12PSI
Some info I collected during research
Not sure if useful
04Z4R 3.0 6 speed VF supercharged,Tial BPV,Ceramic coated Bimmerbrakes header, megan motor&trans mounts,42 design catch can, custom intake ducting,2.62 blower pulley,pre and post S/C WMI,CDV delete ,custom strut bar,3.64LSD, H&R anti roll bars, adjustable Hotchkis end links.Eibach Pro Kit,Koni Yellows. Carbon dipped interior.
dbarton62 is offline   Reply With Quote
Old 07-21-2016, 02:56 PM   #23
rkneeshaw
My Ride: 330i ZHP
Not sure if useful
Hey bdarton, are those PDF's from cat cams the specs on stock cams out of the M52TU? Or are those regrind specs?
I wish we had something like that for the ZHP cams
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Sponsored Links
Advertisement
Old 07-21-2016, 05:26 PM   #24
dbarton62
Not sure
I got a quick email response from CatCams on a couple of questions when I did my research.
Can't recall my questions.......send them a note.
Old 07-21-2016, 09:34 PM   #25
rkneeshaw
My Ride: 330i ZHP
Not sure
Good idea, done!
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Old 07-22-2016, 12:56 AM   #26
TerraPhantm
My Ride: M3
Also of note is that between the ZHP and non-ZHP base tunes, the VANOS settings, ignition timing, and fueling are all identical.
Old 07-22-2016, 04:20 AM   #27
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
Here are the data sheets for the Schrick 248/248 cams.
Might help.
I am running these in my 323i with great results.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 07-22-2016, 03:23 PM   #28
sbrach
My Ride: E46 and E53
I believe you as you know a lot more about these DMEs than I do but isn't it comparing apples to oranges since one uses MS43 and the other MS45.1? Couldn't the same base maps produce different results due to wideband control and different knock control strategies as well as other variables between the two DMEs?
-Steven
sbrach is offline   Reply With Quote
Old 07-22-2016, 04:16 PM   #29
TerraPhantm
My Ride: M3
There are non-ZHP 330s with the MS45.1 (all US-spec RWD non-M E46s made from March 2003 onward use the MS45.1)
Old 07-23-2016, 05:01 PM   #30
sbrach
Ahh, that makes sense. I thought only ZHP cars got the MS45.1.
-Steven
Old 07-23-2016, 09:27 PM   #31
reggid
My Ride: .
This is a schrick 248 intake cam, firstly I dialled the indicator to 0 on the base circle (image 1429)
Now to make this easy and near enough to accurate as I can, I have used a spirt level on the front of the cam bolts (image 1430)
The first reading is 0.0156 (image 1432)
I then rotated the camshaft anti clockwise again and levelled the front bolts but this time I placed the spirit level from below the bolts (two bolts level at the bottom rotation, image 1434).
The reading was 0.3355 (image1436)
I then rotated anti clockwise one last time till I could level the front cam bolts at the top position again.
The reading was 0
This may help you rule out if the ZHP cam is or isnt the same as the schrick 248, in a relatively easy manner. It is the only relatively easy way I can think to help without access to a ZHP cam, and could be done with the cam in the car.
get yourself one of these it is easier to find the peak of the lobe. you just unscrew your ball tip of the dial indicator and screw the new one in.
https://www.machineryhouse.com.au/Q2165
reggid is offline   Reply With Quote
Old 07-23-2016, 09:38 PM   #32
Davew
My Ride: 2004 330ci Msport
I think you are missing my point of trying to help someone verify a cam profile with some basic tools and a few easy points to approximate. The Aim was to confirm or deny one profile.
Davew is offline   Reply With Quote
Old 07-23-2016, 09:58 PM   #33
Rob43
My Ride: 03 331Ci 5spd R1200R
Roy Carvalho <[email protected]>
To ***Rob43*** Jul 21 at 8:46 AM
Dear Robert
Many thanks for your below Schrick cam enquiry.
Firstly, where are you located for delivery please so I can quote correct prices and shipping ?
Europe never got the ZHP model, so whilst we cannot confirm 100% the OEM cam specs, I am sure you are are not far off at around 248 degrees, perhaps a little less.
We have had good results from both the 264/248 and 272/254 degree Schrick sets.
Depending on cars mileage, you may want to consider new valve springs too ?
Please let me know on the above and I will be happy to send you back a quote on what items you wish
Very best regards
Roy
Please let me know if we can help further.
Regards
Roy
**We will usually beat any other genuine quote !**
PLEASE INCLUDE PREVIOUS EMAIL CHAIN WITH ANY REPLY
www.ca-int.co.uk
+44 (0)1202 822 792
The information in this email is confidential and may be legally privileged. It is intended solely for the addressee ONLY. This e mail may NOT be forwarded to another person nor reproduced in any format in any publication, internet forum or other media without the express permission of CA technologies International . Access to this email by anyone else is unauthorized. If you are not the intended recipient, any disclosure, copying, distribution or any action taken or omitted to be taken in reliance on it, is prohibited and may be unlawful.
Sent: Thursday, July 21, 2016 1:13 PM
To: Roy Carvalho <[email protected]>
Subject: WG: BMW 330 ZHP Cam
Rob43
SUMMIT POINT WV 1:24:229 SCCA
(DynoDynamics
Dyno Video)
Old 07-18-2018, 08:57 AM   #34
rkneeshaw
My Ride: 330i ZHP
Took two years, but I've got measurements from a set of ZHP cams from a cam performance shop. Here's how they stack up:
Stock B30:
Intake 240 degree, unknown lift?
Exhaust 228 degree, unknown lift?
ZHP:
Intake 246 degree, 10mm lift
Exhaust 237 degree, 9.4mm lift
Schrick 248/248 set:
Intake 248 degree, 10mm lift
Exhaust 248 degree, 10.8mm lift
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
Old 07-18-2018, 10:46 AM   #35
ctlikon
My Ride: 2005 330Ci Coupe
Year: 2005
Model: 330CI ZHP
Transmission: ZF S6-37
Ive been lurking waiting for an update, Thanks for posting!
"We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art." Chris Bangle
ctlikon is offline   Reply With Quote
Old 08-18-2019, 03:57 PM   #36
rkneeshaw
My Ride: 330i ZHP
Finally did a cam swap on my car. Pulled out the ZHP cams and took some pics for reference. They are different than the Schrick cams (248/256) that I installed. Here's all the markings I could find:
2003 BMW 330i ZHP
Build thread:
Wheelwell:
Fuelly:
