Reducing # of maps (MS43) - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-12-2017, 10:56 AM   #41
daniel_f.
My Ride: 330iC
IGAB is the only map used and its using the highest values the ecu can use from map ip_iga_tco_1_pl_ivvt__n__maf, of course with interpolation as IGAB is smaller.
No further development on MS4x from me.
Old 09-02-2017, 04:45 PM   #42
rb01
My Ride: 323i 98 208HP->Turbo
Will try to setup program on few maps, isaless and boosted.
It would be nice to turn off all enrichments..
Update:
Works great
rb01 is offline   Reply With Quote
Old 12-24-2017, 03:21 PM   #43
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
Transmission: 5 spd manual
Update:
Works great
Can u implement launch control on FewMaps ?
scorpionreptyle is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-19-2018, 01:14 AM   #44
cwarel
My Ride: 330ci coupe
Can somebody please upload a few maps version of bin with RS4 maf scaling adjusted because i cant just copy and paste it wont let me do it in full flash ( m54b30 )
cwarel is offline   Reply With Quote
Old 11-07-2018, 08:00 PM   #45
YoitsTmac
My Ride: 01 330Ci "Mia"
If we're not on this beta, should we be running the cold start cam maps for the at temp maps?
edit: also can someone chime in on what full load detection is? I'm searching around and coming up empty handed
BMWCCA GGC: 530872
YoitsTmac is offline   Reply With Quote
Old 12-28-2018, 11:00 AM   #46
rbngr
My Ride: e46 325ti
Is it possible to release a variant where a "big" ignition table is used? I think it would be easier this way as you have finer control and can directly use these table in a full bin. I think Alpina used the large cold ignition table.
rbngr is offline   Reply With Quote
Old 12-28-2018, 06:26 PM   #47
LKMT
My Ride: N/A
If you are comfortable with patching the binary yourself then this is what needs to be changed in the 430056 fewMaps 512KB binary.
Replace E6 FC 70 47 at 0x30810 with E6 FC 7C 47 to replace ip_igab_is__n__maf with ip_iga_tco_1_is_ivvt__n__maf
Replace E6 FC 88 47 at 0x30A76 with E6 FC 94 47 to replace ip_igab__n__maf with ip_iga_tco_1_pl_ivvt__n__maf
LKMT is offline   Reply With Quote
Old 12-28-2018, 07:42 PM   #48
rbngr
My Ride: e46 325ti
Thank you very much. I did that and right now i am setting up the tables.
[EDIT]
Question is if to use the stock "cold" tables or a blend between "warm" and "cold"...
The original fewMaps files seem to use the cold values.
[/EDIT]
Old 12-28-2018, 08:54 PM   #49
rbngr
My Ride: e46 325ti
Here is what I have done:
  • The two new ignition tables are filled with the stock cold values.
  • The two basic tables are filled with the stock values again.
You can download the .zip here
Only tested on a B25 so far.
Old 12-29-2018, 08:03 AM   #50
LKMT
My Ride: N/A
  • The two new ignition tables are filled with a weighted average of three parts stock warm value and one part stock cold value.
WARNING, not tested yet!
You need to double/triple check your patches before posting them online
I had a look at the files and in the B22 and B25 file the patch for the ip_iga_tco_1_pl_ivvt__n__maf table at 0x30A76 is incorrect, a C has replaced a 4 in the B25 file and a 7 in the B22 file.
Old 12-29-2018, 08:43 AM   #51
rbngr
My Ride: e46 325ti
Oh boy, how the hell did that happen?
Thanks for taking a look.
Fixed it, doublechecked with hexdiff, updated the .zip and I am going to flash it right now.
Old 12-29-2018, 10:32 AM   #52
rbngr
My Ride: e46 325ti
Works fine on a B25
Old 07-18-2019, 02:32 PM   #53
Rogue Pyro
My Ride: 2003 325i
Keys not recognized after flashing original tune.
I flashed this tune onto my car a couple of years ago but now I'm trying to go back to the original. After flashing back to the original my keys no longer start the car. Is there some kind of procedure to reset the keys?
Rogue Pyro is offline   Reply With Quote
