WTF front diff flange - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 02-03-2017, 05:55 PM   #1
WilloCO
My Ride: '05 330xi 6 speed
So I finally got the stupid cheap axle out of the front diff today and pulled the diff itself.
My replacement diff is identical (aside from gear ratios) with the exception of the input flange.
The flange of the diff from the car is smaller and looks like a freakin X5 flange.
The flange on my new diff looks like every other 330xi diff I could find a picture of.
Any thoughts here? The old guibo is slightly smaller in diameter than the flange holes of my 330xi auto diff. I'm thinking it may be easier to find another front axle to match with the front diff.
Effing wierd.
WilloCO is offline   Reply With Quote
Old 02-03-2017, 05:58 PM   #2
zander271
My Ride: 6spd ZHP/5sp XI
Can you swap the input flange?
Old 02-03-2017, 06:03 PM   #3
WilloCO
Yeah, it's a pain to keep preload the same. Probably have to buy an analog torque wrench to do that.
Sponsored Links
Advertisement
Old 02-03-2017, 07:56 PM   #4
Mariner05
My Ride: 2005 325xi
Are we talking about front drive shaft and how it connects to the front diff input flange ?
There was a change at some point, and early xi's did not have a Guibo at the front end of the front drive shaft (see Bentley manual section 260) where it attaches to the front diff input. Bentley only shows the early version without Guibo - did not match my '05 325xi, which has one. If you source a used driveshaft from an earlier car to match the diff, then be careful of possible balance issues as well as the diff input preload.
Wish I could be of more help,
Mariner05
Mariner05 is offline   Reply With Quote
Old 02-03-2017, 09:46 PM   #5
GCoop
My Ride: '04 325xi
My '04 does not have a front dive shaft GUIBO. Was it just the '05s?
Build date 11/03
GCoop is offline   Reply With Quote
Old 02-04-2017, 12:01 AM   #6
Swiff
My Ride: 2002 330xi
Go to realoem.com and put in the last 7 of your VIN and then go to front axle and scroll down to the differential picture and get the part number. Then google the number and see who sells it. It may have been from another vehicle model (E90 for example). The 330xi have seen some different front differential part #s and different length front drive shaft for the 6 speed models.
Swiff is offline   Reply With Quote
Old 02-04-2017, 10:13 AM   #7
WilloCO
I called some diff shops and was pretty disappointed by them. They're all afraid of imports.
I've ordered a new small torque wrench so I can measure preload. My concern now is that the original diff has a shaft that sticks out to align the drive shaft. My new diff doesn't have that shaft...
Here's an example:
Old 02-04-2017, 11:17 AM   #8
WilloCO
Yup, after looking at this a bit more I think the best option is to buy the older style drive shaft. I will crawl under and verify that the output flange on my transfer case is 4 bolt.
From some parts diagrams, there are two styles of the shaft. The 4 bolt was used on most of the cars, while the three bolt/guibo version was used on a subset. I suspect it was limited to manual transmissions. My new diff was from a 2005 automatic...
Old 02-04-2017, 03:41 PM   #9
GCoop
My Ride: '04 325xi
I bet you are right about the guibo on the front drive shaft and corresponding output flange being for manual XIs. Know that you say that it seems to ring a bell. Mine is an automatic and is the same as what you have described.
Old 02-04-2017, 03:57 PM   #10
WilloCO
Yeah, parts compatibility checking seems to prove out the manual vs auto idea. I think I'll be ok switching to the old style since they did use it on them for a while.
Crawled under and verified, the transfer case does use the regular 4 bolt mount.
Old 02-05-2017, 04:51 PM   #11
zander271
Weird, wonder why they used different designs on the diffs. What doesn't change is the AT front diff from 01-05.
03/2003 from
http://www.realoem.com/bmw/enUS/show...diagId=31_0568
02/2003 up to
Regarding the different front drive shaft design. Looking at realoem the change was made in 03/2003 but this only applies to manual gear boxes.
03/2003 from
http://www.realoem.com/bmw/enUS/show...diagId=26_0181
02/2003 up to
Old 08-04-2019, 09:37 PM   #12
wfx32
My Ride: AWD
Model: 330XI 08/2004
Transmission: auto
mechanic here says this bolt is missing (above) .. this is the front differential flange, right? i am confused about the front drive shaft and differential flange on the 05 .. it doesn't seem to match realoem Front diff., components, all-wheel (31_0568)
it looks very much like the flange from this rmeuropean diy (above), but maybe i have a different type of front drive shaft?
wfx32 is offline   Reply With Quote
Old 08-05-2019, 10:03 AM   #13
Mariner05
My Ride: 2005 325xi
Yes, you are indeed missing a bolt. The rest of the parts scenario is rather complex, as you can see from the thread so far.
My first thought is to match the other flange bolts, reassemble, torque properly, and see if it fixes your problem (replacing Guibo, if present). These cars are now older, so without complete maintenance records your car might have parts cross-fitted - things that fit, but were not original.
I see my last post to this thread was 2.5 years back. I still drive the car, and it's running well at 205K miles. I hope to drive it another 2 years or so and get it to 250K.
Mariner05
Old 08-05-2019, 03:52 PM   #14
wfx32
My Ride: AWD
Transmission: auto
thanks, that was my thought as well. i have all of the records from the second owner (bmw fairfax) but nothing from the first owner (bmw sterling). they must have replaced the front diff or front driveshaft and forgot one of the bolts. realoem is no help here, so i will have to try to match the other bolts.
Old 08-11-2019, 05:30 PM   #15
WilloCO
You have an automatic front diff, dunno what trans you have, but that's the auto. The Manual is different - thus this thread to begin with.
I would just pull one, go get a temporary metric for now, and order up the replacement in the meantime.
I bedded my pads when I switched from ceramic to my PDF-Z pads. They actually caught fire during bed in.
05 330xi 6 speed
RIP: 86 e30 w/E36 M3 suspension build
