MS45.1 Engine into MS43 Equipped Car...? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 04-09-2018, 01:49 AM   #1
d_cleverzz
My Ride: Turbo 5spd 330cic
Year: 2001
Model: 330CIC
Transmission: 5 Speed Manual
I currently have a 2001 330cic equipped with MS43.
Last night, I did the classic “money shift” and damaged cylinders 1-3. Not sure exactly what the problem is but they don’t have any compression. Although cylinder 2 has about 50.
Anyway,
Found 2 parts cars, 2005-2006 330ci’s . If I’m not mistaken, are both equipped with ms45.1.
Will it be possible to drop one of those engines into my ms43 330 and it would run properly?
If not, what needs to be changed?
Any information,advice, and/or insight would be greatly appreciated.
Thank you.
Your friendly turbo 330cic,
d_cleverzz
d_cleverzz is offline   Reply With Quote
Old 04-09-2018, 02:00 AM   #2
gtride
My Ride: 330 Touring
Nothing needs to be changed. Just keep your intake manifold ms43, wiring harness ms43 and cats (or just keep you bank 1 O2 sensors ms43). Same engine, only difference is accessories.
Sent from my [device_name] using E46Fanatics mobile app
gtride is offline   Reply With Quote
Old 04-09-2018, 02:03 AM   #3
armenh7
My Ride: 2002 325i
Exactly. The changes happened to the coil packs, coil pack wiring, o2 sensors, maf, and intake air temperature sensor. Just swap over all the stuff from your original engine and you'll be fine
armenh7 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-09-2018, 02:04 AM   #4
d_cleverzz
Year: 2001
Model: 330CIC
Okay, great news.
The original engine in my car now has catless headers with only pre cat 02 sensors.
So as long as I equip the ms45 engine with the catless headers and the ms43 intake manifold from the original engine, all should be good?
Can you explain the wiring harness, I get a little confused on what harness and where it exactly is located.
d_cleverzz
Old 04-09-2018, 02:05 AM   #5
d_cleverzz
Year: 2001
Model: 330CIC
Awesome, thank you.
d_cleverzz
Old 04-09-2018, 02:16 PM   #6
d_cleverzz
Year: 2001
Model: 330CIC
The engine may be off an automatic, if so.
I just have to instal the flywheel from my engine right? (My E46 is a 5 speed manual).
Also, what would happen if I used the wideband o2s from the ms45.1 engine with my ms43?
d_cleverzz
Old 04-09-2018, 03:58 PM   #7
gtride
They will not work with ms43. Wide band got different connectors on O2 sensors.
Old 12-05-2018, 12:51 PM   #8
Zero Cool
My Ride: 04 325Ci, 91 318iS
the alternator plug may be different also.
Edit, just saw the date. never mind.
Zero Cool is offline   Reply With Quote
