'02 325ci Coolant System and Brake Caliper Questions - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-22-2018, 04:01 PM   #1
pnMedia
As always thanks for the expert insight and guidance ..
I'm the original owner of this noted 2002 325ci. Only 31k miles. I ordered it back then with the available "Sport Package" option.
For the lifespan of the car I've lived in a high-rise with an outdoor lot that is located about 200ft from a salt water bay. Needless to say the exterior of the car has suffered. The clear coat is starting to peel in various areas due to direct sun exposure. The aluminum trim and rubber seals have begun to show signs of deterioration as well. Considering - the car still looks decent. Eventually I'll address the exterior.
By the way - I've never had any mechanical problems with the car. Everything with regards to parts is 100% original outside of the windshield washer fluid pump, windshield cowl, rear brake pads, and the tires. Oil has been changed as needed. Air filter and cabin filter have been maintained as well.
Anyway -
Question #1 - I understand the design of the coolant overflow tank and I guess the radiator with the blue drain screw located under the car. I'm also aware of the bleed screw, located at the top of the overflow tank. I've read that there is another drain screw that will allow coolant mix drainage from the engine block. If so, is the coolant mix that is located in the radiator/overflow separated from the coolant mix located in the engine block? What's the correlation?
Question #2 - Regarding the brake calipers. All four are completely covered in surface rust. I understand that rust is inevitable, especially in my location. However, does this rust compromise functionality and/or safety? I will say the car brakes efficiently, with no indication of malfunction or pad wear. Should I consider having these replaced? If so, any recommendations, other than the $400 versions that BMW sells?
Thanks again..
-paul.
pnMedia is offline   Reply With Quote
Old 08-22-2018, 04:19 PM   #2
CylonRed
My Ride: '01 E46 330i sport
Q1 - coolant circulates in the engine block and then back to the radiator to get cooled off and then it is recirculated in the block. It is all the same fluid... Emptying the hoses and expansion tank only removes most of the coolant. If you remove the water pump more fluid will come out from the top of the engine. The added screw in the block will drain the upper part of the block of the fluid and get pretty much all of it out.
Q2 - nope - not unless the caliper pins are sticking but that is separate from the general caliper surface rust.
CylonRed is offline   Reply With Quote
Old 08-22-2018, 04:45 PM   #3
Sapote
My Ride: 2000 323i auto wagon
for a complete draining coolant job, drain the radiator, empty the tank, and drain the engine block.
As for the rusted calipers, just give them a good coat of engine oil or grease.
Sapote is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-23-2018, 09:38 AM   #4
markusmarkus
My Ride: 2018 M240i
The engine coolant drain plug is located between cylinders 1 & 2 under the exhaust manifold. If you remove it you MUST replace the crush washer. Failure to use a new crush washer will result in a coolant leak. Ask me how I know!
Old 08-23-2018, 10:59 AM   #5
orb
My Ride: 325Ci
You could paint the calipers to help curb the rust, usually requires a few hours of sanding and cleaning if you’re up for that.
orb is offline   Reply With Quote
Old 08-23-2018, 12:53 PM   #6
pnMedia
Everyone - thanks for the responses.
-paul.
calipers, radiator
