Difference between early and late M54 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 09-06-2018, 11:04 PM   #1
CrusherCurtis
My Ride: Subi
What's needed to make an 03 to 05 m54 work in my 01? My researching is showing that something is different.
CrusherCurtis is offline   Reply With Quote
Old 09-07-2018, 12:52 AM   #2
armenh7
My Ride: 2002 325i
03/03 BMW switched to MS45.1 but since your car is 05 it already has it. If you get an engine built before 03/03 everything should still work fine. 09/02 is when the M54 got the newer valve cover for the pencil style coil packs
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 09-07-2018, 12:00 PM   #3
HayWagon
My Ride: 03 330iT
I beleive he is swapping an 03-05 engine into his 01.
Minor differences, MAF, SAP, O2 sensors, Valve cover.
The engine, intake manifold, TB is the same.
Sent from my tractor.
HayWagon is online now   Reply With Quote
Sponsored Links
Advertisement
Old 09-07-2018, 12:29 PM   #4
armenh7
My Ride: 2002 325i
Right right. I read about the 01 part but seemingly forgot about it
Old 09-09-2018, 02:36 AM   #5
CrusherCurtis
My Ride: Subi
Done more research from this tread
https://www.e46fanatics.com/forum/sh...1113404&page=2
Based on the tread (and list below), is it safe to assume that If I have a running MS43 car (01 325i), a MS45.1 engine will drop right end and I won't need to change/source anything??
-DME (obviously)
-MS43 engine harness
-Transmission/O2 sensor harness, whether you have a manual or automatic transmission
-MS43 MAF (doesn't have built-in IAT sensor)
-IAT sensor (intake air temperature)
-MS43 O2 sensors
-Coil pack harness
Old 09-09-2018, 04:25 AM   #6
armenh7
My Ride: 2002 325i
-DME (obviously)
-MS43 O2 sensors
-Coil pack harness
You can drop in a MS45.1 engine into an MS43 but as you said above, you will swap all from old engine to new engine:
Coil packs
Valve cover
O2 sensors
MAF
Intake manifold (ms43 has IAT sensor plugged into intake manifold but MS45 has it blocked off)
Old 10-08-2018, 04:17 AM   #7
paraklas
paraklas's Avatar
My Ride: B30_TS2++
Year: 2001
Transmission: 5-Getrag
Vibration damper is different. Pre-2003 is 5-rib, post-2003 is 4-rib (for the AC compressor). You either need to swap dampers, AC compressors OR use a 4-rib belt and leave 1 groove blank on the AC compressor (the inner one)
paraklas is online now   Reply With Quote
Old 10-09-2018, 09:27 PM   #8
CrusherCurtis
My Ride: Subi
Coil packs
Valve cover
O2 sensors
MAF
Did this and it won't start, no fire. Any suggestions?
Old 10-10-2018, 01:04 AM   #9
armenh7
My Ride: 2002 325i
Crank or no crank?
Old 10-10-2018, 03:39 AM   #10
CrusherCurtis
My Ride: Subi
Crank
Old 10-10-2018, 12:41 PM   #11
philliplong
My Ride: 325Ci M54B30 6 Speed
Year: 2002
Model: 325Ci
Transmission: Manual
No need to swap the intake manifold, just pull the plug out and stick the IAT in the hole. Make sure the area around the hole is super clean before removing the plug though.
philliplong is offline   Reply With Quote
Old 10-10-2018, 08:02 PM   #12
armenh7
My Ride: 2002 325i
Crank
Can you get a video of the rpm gauge while cranking?
