M54B25 swapped into 2000 323ci dme questions - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 03-31-2019, 01:18 PM   #1
ajpenn1027
My Ride: 1999 323i e46
I bought the car preswapped. As in all he did was put the engine and trans 9n the mounts. What he told me is that all I need to do is wire it and itll work just fine as he has done several m54 swaps into m52 cars. Said I would have to use m52 intake manifold and maybe get a 2.5L flash. But the m54 manifold is still on the engine. And the m54 wiring harness is still on the engine. It looks as if everything will plug in. I'm just not sure if the DME will read the info.
The car still has the MS42 DME. I understand the m54s use the MS43 DME. If everything plugs in like it's supposed to will it run? I pulled the engine out to clean the old oil residue and such up out the engine bay for paint. So I'm getting all my info together now.
Thanks in advance. I've owned and worked on several bmws. M54 and older. So you can use bigger words and be blunt with me. I'm not scared of work.
Authorized AMSOIL Dealer
to access the AMSOIL Online Store
to find out more on how to save money on all your AMSOIL orders!
ajpenn1027 is offline   Reply With Quote
Old 04-01-2019, 01:57 AM   #2
armenh7
My Ride: 2002 325i
It'll run but there are minor differences and you won't have the power advantage
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 04-01-2019, 03:27 PM   #3
infoboy
My Ride: 325ci
Maybe it will turn on but the throttle wont work because m54 is drive by wire
Sent from my SM-J415F using E46Fanatics mobile app
infoboy is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-01-2019, 05:18 PM   #4
HayWagon
My Ride: 03 325iT
You need to replace the m54 drive by wire throttle body with the cable driven one originally on the 323.
The ms42 won't have a clue what todo with a drive by wire throttle.
Sent from my tractor.
HayWagon is offline   Reply With Quote
m54 swap, m542 to m54
Similar Threads
Thread Thread Starter Forum Replies Last Post
*** Sub frame Damage *** Sign here if you have this Problem (Letter to BMW) 02BMW330ci General E46 Forum 1518 05-02-2019 10:30 PM
Purchasing an E46 + Subframe Lawsuit? N89 General E46 Forum 38 12-30-2009 01:43 AM
