e46 330ci - schmiedmann SCM5254 kit touches gearbox - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-28-2019, 01:20 PM   #1
Irbis
My Ride: E46 330ci
My e46 has mounted the following schmiedmann kit: https://www.schmiedmann.com/en/produ...roduct=SCM5254 The exhaust pipe touches a gearbox and a gearbox mounting. It leads to vibrations. I have marked those places in attached pictures:
https://ibb.co/wMb1rnF
https://ibb.co/KzgyszS
Does anyone had that problem ? What is the best way to deform a little bit the pipe in that places ?
Irbis is offline   Reply With Quote
Old 06-26-2019, 04:07 AM   #2
sparky300
My Ride: 04 IMOLA ZHP 6spd
Year: 2004
Model: 330i
Transmission: 6spd
Hmmm...as someone who has been looking at this particular exhaust kit, I'm curious. That's the 1-3 collector that's touching the bellhousing?
From your sig you have a 330? Which transmission do you have?
sparky300 is offline   Reply With Quote
Old 06-26-2019, 04:58 AM   #3
t651
My Ride: BMW
I bought the e39 version (same headers, different mid pipe) and had the same issue.
The fitment was designed for cars with manual gearboxes with the corresponding transmission mount.
For autos it fouls exactly where you've noted.
To clear the bellhousing I put the pipes into a press and squashed at the collectors. For the mid section I had an exhaust shop cut up the pipes and remade a custom center.
t651 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-26-2019, 10:53 AM   #4
mjdarg
My Ride: 2003 330i ZHP
Transmission: Manual
In Schmiedmann's pictures during install, the car is an auto. Have you contacted them?
mjdarg is offline   Reply With Quote
Old 06-29-2019, 12:45 PM   #5
Notaligned
My Ride: 328Ci
How about rear O2 sensors, did they extend to Schmiedmann O2 bungs without having to splice and extend them? This is most common complaint, it's useful to hear some success story too.
Notaligned is offline   Reply With Quote
Old 08-11-2019, 06:22 AM   #6
Irbis
My Ride: E46 330ci
Hi, just for clarification: my e46 is 5 speed manual (2002). Finally I have fit the schmiedmann kit. The best solution is to cut a little bit a gearbox. It is not a big problem. The lambda probes wires are length enough to connect them behind the new catalysts. Everything works fine, I have no engine errors. There is also a problem with mounting a rectangular exhaust support. I haven't adjustted those parts yet. I wonder if the exhaust support is really necessary.
If you have any questions you can contact Schmiedmann directly.
