[MS4X] Siemens MS43 Community Patchlist for Tuner Pro - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-11-2019, 05:21 AM   #41
FritzP
My Ride: BMW E36 BMW F11
MS 43 config. Seeing in M4X Wiki. There are ongoing work regarding configuration for different engine, like 4 cyl. Is this possible. I have an E36 with M42 engine. Fitted with individual throttles. I am lookin for an other ECU than the 1.7.2 Motronic.
FritzP is offline   Reply With Quote
Old 07-11-2019, 06:42 PM   #42
danius375
My Ride: BMW 330ci (E46)
This might save someone a lot of time. If you get the "TPS Adaption" fault come up after adding launch control, all you need to do is set lc_swi_cal_mon_cks to 165.
danius375 is offline   Reply With Quote
Old 07-17-2019, 06:22 AM   #43
thecos
My Ride: 2002 325i Sedan
Originally Posted by clouro View Post
So, today tried following some of the steps people mentioned that have worked for them. Car is a 2002 E46, 325ci - US (used version M54B25-US BIN).
I cloned my OEM ECU onto a new ECU. Used JMGarage and boot mode to flash the original BIN onto the ECU. Through INPA< I checked that VIN number matches. Also checked HEX for ISN and it was all good. I then synced EWS and the car started fine. So far so good! I then wrote the version 69 (keeping EWS) onto my ECU using Chipster. I re-synced EWS and the car cranks but does not start. I tried clearing adaptations and it still won't run.
To check if I didn't do anything wrong, I re-wrote the original software (again) and the car started fine. I then tried writing version 69 with EWS delete. Once again, the car cranks and does not start. I tried clearing adaptations again and it still won't start.
Any ideas of what I could try to get this to run? It seems like the EWS is not allowing the car to start... Previous versions work flawlessly
Is the temp gauge going to red?
thecos is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-17-2019, 09:32 AM   #44
clouro
My Ride: 2002 325ci
Year: 2002
Model: BMW E46 325ci
Transmission: 5-speed manual
Hi thecos,
The temperature gauge is not going to Red. I used Chipster, so Checksum was corrected.
clouro is offline   Reply With Quote
Old 07-17-2019, 10:46 AM   #45
thecos
Hi thecos,
Are you changing the ISN and Vin on the 69 file before doing a full write with Chipster? But you said you sync'd the EWS so I guess you are? Not sure what's going on since you seem to be taking the same steps I took to get the 69 file running on my car... The only difference I see is that you didn't mention writing your VIN into the 69 file. The ISN is FF so it takes it from the EWS (?) but it doesn't hurt to copy it from your original file, that's what I've always done.
Old 07-17-2019, 06:52 PM   #46
danius375
What fault codes do you see when you try to start it?
Old 07-17-2019, 06:56 PM   #47
clouro
My Ride: 2002 325ci
Year: 2002
No error codes show up. The car simply cranks and doesn't start, but the "Service Engine Soon" does not light up
Old 07-17-2019, 07:01 PM   #48
danius375
From my experience you always get a fault code when the engine doesn't start. The most common one I was getting was TPS-Adaption or EWS fault.
Old 07-18-2019, 01:19 AM   #49
SiBriers
My Ride: 325ci 02 Sport
Year: 02
Model: 325ci Sport
Transmission: 5MT
I'm seeing a similar no start situation on my UK 2002 325ci.
DSC and EML lights stay on and get a clicking noise before it cranks without starting.
Patched EWS only before flashing with Chipster.
Car starts OK on pretty much any v56 file, including on a spare junkyard DME.
Appreciate all the hard work doods. Thanks.
SiBriers is offline   Reply With Quote
Old 07-21-2019, 07:06 PM   #50
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
Transmission: 5 spd manual
maybe has something to do with ecu hw number ? after flashing v69 i`m unable to comunicate with ecu ,no inpa connection - module doesnt match -kind of error ,mssflasher - unsupported ecu. tried multiple times,unable to start , no connection to ecu. Maybe someone is willing to share their working full file...
scorpionreptyle is offline   Reply With Quote
Old 07-21-2019, 10:31 PM   #51
armenh7
My Ride: 2002 325i
V69 is still iffy. I tried a test file and it worked but only unpatched. I haven't had success with the files on the wiki
armenh7 is offline   Reply With Quote
Old 07-22-2019, 08:52 AM   #52
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
Can you give me that file?
Old 07-22-2019, 09:28 AM   #53
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
Main errors from inpa,for nonstarting v69
Old 07-22-2019, 12:16 PM   #54
stefm5
My Ride: 2001 530i
Originally Posted by stefm5 View Post
today i had the time to try for first time to flash e39 ms430069 version. i opened the binary in tuner pro, patched maf hack, ds2 logging and cluster mod. flashed with chipster in fast mode.
boom it works.
i attach a working file for me. (E39)
stefm5 is offline   Reply With Quote
Old 07-22-2019, 01:52 PM   #55
Iliyasuper
My Ride: 316 with M54b30
Firs at all Thank yousda2 Great job!
Every day i`ve been waiting update of wiki!
What about Extended DS2 Logging? I`ve already activated, but where may i monitor new parameters? Automatically will have added to test-o/inpa ?
Attachment 780129
Attachment 780131
Attachment 780133
Same error..
Somebody know, what does it mean LHD and RHD?:
Siemens_MS43_MS430069_E46_M54B30_EU2_LHD.bin
Siemens_MS43_MS430069_E46_M54B30_EU2_RHD.bin
Iliyasuper is offline   Reply With Quote
Old 07-22-2019, 02:27 PM   #56
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
Same error..
Left Hand Drive / Right Hand Drive....it was explained...
I think it has something wrong on ews delete feature. There are less errors without that patch. Control unit failure one does not come up without ews patch. unfortunately,for swap guys with ews phisically removed,there is no sync option available,so no engine start.
Old 07-22-2019, 11:37 PM   #57
armenh7
My Ride: 2002 325i
You can manually delete EWS
Old 07-23-2019, 02:02 AM   #58
scorpionreptyle
My Ride: e36 330i
Year: 1997
Model: E36
Whats the adress,what to change? base data must be replaced with patch data (from xdf refference) ?
600D8 from DA 0A 6C DD to DA 0D F8 3B
53BF8 from 00 00 FF FF FF FF FF FF to DA 0A E4 FC 0E 1A DB 00
70A6E from 02 to 00
Old 07-23-2019, 09:22 AM   #59
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
Where is the list of abbreviation definitions for ms43? I know I've seen them before at some point
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 07-23-2019, 09:40 AM   #60
10le
My Ride: e46 325Ci
Year: 2002
Model: E46
Transmission: MT
https://www.ms4x.net/images/c/c7/Abbreviations.pdf
10le is offline   Reply With Quote
