MS43/42 DME hardware - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-09-2019, 06:37 AM   #1
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
Has anyone had the time to disect the DME hardware on MS42/43 DME's?
I am specifically asking in regards to the knock sensor conditioning circuit.
I can't find my old DME's I have opened up and was hoping that someone else had some insight into "inner workings" of these things.
I know that they run piezo knock sensors which makes it near impossible to just measure the sensor to get it's parameters.
I am doing this so I can re-purpose my spare sensors for other projects and use my current fitted(disconnected) sensors on my modified engine.
Any ideas/help appreciated.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 08-05-2019, 08:36 PM   #2
Blu302
Year: 98
Model: E46
For anyone interested,
It uses a differential signal into a knock IC.
It has a series of 2KΩ resistors mirrored on each "leg" of the sensor with a basic filter. The sensor has a bias voltage applied to the signal output end of the string.
Old 08-06-2019, 05:11 AM   #3
SiBriers
My Ride: 325ci 02 Sport
Year: 02
Model: 325ci Sport
Transmission: 5MT
Interesting - are you thinking that the filter components could be changed / tuned to allow a bit more knock then?
SiBriers is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-06-2019, 08:36 AM   #4
Blu302
Year: 98
Model: E46
I am running the sensors into a custom knock IC as the factory DME is long gone. The readings I have measured are noisy and random. I am going to put it through an FFT and pull the frequencies related to knock.
The factory system is broad band and integrates the total signal to get the overall level of knock. The factory system is not "tuned" enough to allow for easily running at the knock limit and not having timing pulled randomly.
