Brake Pressure Sensor Connector OEM Replacement - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 07-17-2019, 04:55 PM   #1
Joec03
My Ride: 2000 323ci
I thought I'd post this information here for anyone that needs it. When changing my brake pressure sensors, I ended up breaking one of the brake pressure sensor's plastic connectors, on the wiring harness in the car. After much research I was able to locate a replacement OEM connector, but it had a different part number. It was a bit tricky but I was able to pop out the pins from the old connector and pop them into the new connector. Anyone that needs this information I'll walk you through it.
The part number on the BMW connector is 2-968980-1 which is not available anywhere to purchase. You may also see the part number 968402-1 on the outside housing.
An identical replacement is part number 2-967642-1 made by TE Connectivity (www.te.com). The same company that made the BMW version. It's available at mouser.com and digikey.com The only difference of this connector is the color (green instead of white).
OEM Brake Pressure sensor connector: https://www.mouser.com/ProductDetail/571-2-967642-1
If you need to crimp new wires and can't use the old pins, I still got you covered.
Pins: https://www.mouser.com/ProductDetail/571-5-965906-1-LP
Water proof seal for each pin: https://www.mouser.com/ProductDetail/571-967067-1
Hope this helps anyone that's damaged their harness!
ID:	779813   Click image for larger version
ID:	779815   Click image for larger version
ID:	779817   Click image for larger version
Joec03 is offline   Reply With Quote
Old 08-16-2019, 05:56 AM   #2
cp2708
My Ride: 325ci Convertible
Model: Sport
Transmission: Auto
Thanks for the heads up!
cp2708 is offline   Reply With Quote
