MS42 EWS synchronize procedure...I need some help please! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-20-2019, 07:44 PM   #1
Alchemy Design
My Ride: 330xi, 328, 525, 335
Year: 2001
Model: 330xi
Transmission: Auto
Can someone please give me a step-by-step for re-aligning the EWS with the DME on MS42?
I want to virginize the DME, make it work in my 328, then once start is confirmed, I'm going to custom tune from there.
Well, DME is flashed with virginized BIN file, from the Wiki page, and now when i try to do an ews align, it says ERROR_ECU_REJECTED...
any info for proper procedure is greatly appreciated.
Alchemy Design is offline   Reply With Quote
Old 07-21-2019, 01:48 PM   #2
armenh7
My Ride: 2002 325i
Too bad I can't help you but I experienced the same issue yesterday with MS43 on a friend's car. I flashed a virgin file and the DME would sync with the EWS. I ended up flashing a EWS delete file. The weird thing is virgin files work on my car
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 07-21-2019, 04:40 PM   #3
Alchemy Design
Year: 2001
Model: 330xi
Transmission: Auto
Well I flash the DME with the version file, and that didnít work, so I downloaded the EWS delete and did a full flash, and it still does not work. Even with the EWS delete been file on a fresh flash, Iím still getting a no start condition. No start meaning no starter activation at all. Itís not like itís rolling over and will not, It will not engage the starter whatsoever.
Sponsored Links
Advertisement
Old 07-21-2019, 04:42 PM   #4
armenh7
My Ride: 2002 325i
Originally Posted by Alchemy Design View Post
Well I flash the DME with the version file, and that didn’t work, so I downloaded the EWS delete and did a full flash, and it still does not work. Even with the EWS delete been file on a fresh flash, I’m still getting a no start condition. No start meaning no starter activation at all. It’s not like it’s rolling over and will not, It will not engage the starter whatsoever.
I also experienced that. We ended up putting a jumper between the EWS wires
https://www.rpmmotorsport.net/pages/...or-a-key-issue steps 1-4
Old 10-05-2019, 02:19 PM   #5
JTMillerboy
99 328 saloon Dmema42. No crank no start.......13.5v+ on naytery, fuel yes, fuses good , relays under fuses all swithch andnat right ohms. Have EWS delete done cuz lost key guys. Now should be plug n play....no crank no start full power..........suggestions please? Starter? Some wire swappin? Im stuck. Siys at 13v+ under eng. Bay pos. Term. 13v, 3reds on ign. Switch read 13V. Do i meed do disxonnecr ews and any wires to put togethere? No transponder or antenna ring needed and plug n play .....plug no play. Suhgestions any one please.tjanks so much anyone
JTMillerboy is offline   Reply With Quote
dme, ews, ms42, no start
