help with oil pan gasket replacement in orange county? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Old 08-01-2019, 11:32 PM   #1
b0baboii
My Ride: huh
Year: 2002
Model: 325i
hi
somewhat new ish to the forum and the e46 and working on cars in general. i believe my oil pan gasket needs replacing. is there anyone in orange county that has the tools and time to help me with this little project? i will be forever grateful!
if this isn't the place to put this, my bad!
thank you!
b0baboii is offline   Reply With Quote
Old 09-03-2019, 05:06 PM   #2
fixthatbmw
My Ride: 330i
takes 7 hours avg, chk with lowest priced dealer. they must drop lower front suspension, big job, for access to oil pan. expect to pay 1200.00-1400.00 for the job to be done correctly. dealerships hand the proper tools and training.
while your at it do the valve cover gasket, and have them check the fuel housing gasket.
if you do all the above you will not have any oil leaks for quite sometime.
own a 330i 2001 since new, great car just due the maintenance as required
fixthatbmw is offline   Reply With Quote
Old 09-04-2019, 03:55 PM   #3
YOnpds
My Ride: E46
Since you are new to DIY's, I wouldn't suggest doing the oil pan gasket yourself. Very involved. May cost you at least $600 and up (non dealer). Good luck.
YOnpds is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-05-2019, 12:19 PM   #4
wallaby13
My Ride: '05 ZHP 6MT
oil pan is obviously at the bottom of the motor, which means leaks above it can make it look like it's leaking. Check the oil filter housing gasket and valve cover gasket first. Those jobs are also much more friendly for DIY.
I consider myself a fairly experience DIY'r (done engine/trans swaps ect). I took 2 days to do the pan gasket. About 3-4 hours a day but didn't want to rush it and get frustrated. An engine support brace is required (harbor freight). You also need torque wrenches, and an angle gauge to torque the re-enforcement plate.
wallaby13 is offline   Reply With Quote
