software version for MS45.1 MANUAL program? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 08-08-2019, 01:46 PM   #1
nextelbuddy
My Ride: e46 ZHP
Year: 2003
Model: 330i ZHP
Transmission: 6MT
i just completed MS45.1 ZHP engine into a 2000 323 with auto to manual swap. everything is good and the only CEL is for EGS timeout.
i have removed option code 205 fro Cluster, LCM and installed an M3 MK20 DSC module already set to manual transmission.
i have checked my cluster, DSC and they are all set as manual and LC has no 205 SA code either.
the DME i have is for a 2004 Auto ZHP so im guessing i need to reflash it with the MANUAL software with WINKFP.
does anyone know how to find the manual version of the MS45.1 ZHp software to flash with WINKFP?
i tried using this nifty program i found on M3 forum called Youve got ZBnumberwang and pointed it to my MS451 DATEN folder and it showed a lot of stuff but no where in there does it explicitly state which one is manual and which one is automatic.
i could have sworn that all i had to do wads clear adaptations in the DME using INPA on MS45.1 and it would have set to MANUAL as long as i had the clutch switch wired properly which i do but that didnt work.
thanks in advance!!
2003 e46 ZHP M3 Sedan | S54 6 Speed
2002 e46 ZHP Touring | M54 6 Speed
nextelbuddy is offline   Reply With Quote
Old 08-08-2019, 02:09 PM   #2
nextelbuddy
My Ride: e46 ZHP
Year: 2003
Model: 330i ZHP
Transmission: 6MT
I actually have a manual tune file for MS 45.1 that I used on my last ZHP DME on my last wagon. Could I just flash that or is it like MS 54 DMEs where there's different software version than you cannot mix and match tune files unless you have the proper full file?
I was going to try using Terras new MS-45 flasher software and flash the bin file that I have for my other MS-45 ZHP DME.
I just didn't want to do it if it was going to cause me to brick the DME since it wasn't originally from this DME
Old 08-08-2019, 03:54 PM   #3
nextelbuddy
My Ride: e46 ZHP
Year: 2003
Model: 330i ZHP
Transmission: 6MT
ok im good now
i updated my AUTO ZHP Dme to the latest ZUSB in WINKFP and once that was done i was able ot flash y ZHP TUNE file i had fro my other ZHp car which was from a manual car and now EGS error in DME is gone.
Sponsored Links
Advertisement
Old 08-09-2019, 08:25 AM   #4
Blu302
My Ride: '98 E46 323i
Year: 98
Model: E46
Transmission: Manual
just for future reference, there is no auto or manual DME software. The DME has both in the software and it is set to which 'box when setup in the car.
_______________________________________________
Power is knowledge, So share the knowledge!!
Blu302 is offline   Reply With Quote
Old 08-09-2019, 02:20 PM   #5
armenh7
My Ride: 2002 325i
You just clear "variant" adaptation in inpa
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 08-12-2019, 01:36 PM   #6
nextelbuddy
My Ride: e46 ZHP
Year: 2003
Model: 330i ZHP
Transmission: 6MT
Thanks guys. I did use INPA with the f9 option to clear all adaptations and that didn't get rid of the egs error but maybe I chose the wrong option.
I appear to be good now.. crossing fingers.
Old 08-12-2019, 07:43 PM   #7
Blu302
Year: 98
Model: E46
That is the word I always forget. Thanks!
