Changed fluid & filter on auto gearbox, comments... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 08-12-2019, 09:37 AM   #1
77'911
After purchasing our "xi", I knew all the fluids would need changing, or assessment at a minimum. Tackled the trans service this weekend (along wt the diffs). Got the car up on the lift early in the morning. Unlike the 986, the regular 10mm bolts around the pan are quite easy to deal with. Our car had the pull down filter, which came off easy enough. The o-rings stuck up in the trans though, but came out. Thankfully, the fluid and inside the pan(and magnet) did not look too bad. The kit from BMW has everything you would need, even a new magnet for the pan. Got out a little over 5 liters. Used BMW's factory fluid and a pump from the local auto store. I'll do another fluid drain and refill at the next oil service just to make sure I've cleaned up the fluid. Used the Bentley Manual for torque specs. For the pan bolts at 10Nm, I used a precision instruments, dial type, torque wrench. For the filler/drain plugs, a Sears click type torque wrench. Cleaned out the pan with 3m brake clean, then vacuumed out any dust or lint from the towels after things dried out.
I'd highly recommend, for those with auto gearbox's out there, give them a servicing. The difference afterwards was night and day better. Much smoother, less vibrations, reduced noise, and shifts are what seem to be flawless now.
77'911 is offline   Reply With Quote
