Front vs Rear Wheel Replacement (don't hate me) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 08-13-2019, 06:29 PM   #1
footlox
My Ride: 2002 330xi
2002 330xi with 2002 M3 Rims
I cracked my rim BAD hitting a pothole that a small adult could fit inside of.
The front passenger side rim is what cracked and I'm going to order a used rim from originalwheels.com. (it the 5 spoke starfish looking rim)
https://www.originalwheels.com/bmw-w...m32002rims.php
The problem is there is a likelihood that I rotated/swapped the front wheels for the rear wheels at some point, not knowing they were sized or offset differently.
My question is how can I differentiate a front rim from a rear rim to know for sure?
'02 330xi - Grey Green Metallic - Dinan CAI - Umnitza Angel Eyes
footlox is offline   Reply With Quote
Old 08-13-2019, 08:13 PM   #2
WilloCO
My Ride: '05 330xi 6 speed
XIs run the same saze front and rear. Only the M3 wheels are different. Honestly, just hit CL and find more wheels. I've generally paid 200 with good tires on them!
I bedded my pads when I switched from ceramic to my PDF-Z pads. They actually caught fire during bed in.
05 330xi 6 speed
RIP: 86 e30 w/E36 M3 suspension build
WilloCO is offline   Reply With Quote
Old 08-14-2019, 11:25 AM   #3
jagmandan
My Ride: E46 325xit -> 330xit
Check the inside of the wheel for a part number or size. It should be part of the casting. Alternatively, use a tape measure to confirm if you have different widths in play. If you are running staggered on an xi (some would recommend against this on principle), you will want to make sure your tire sizes result in a very minimal difference in rolling diameter across all wheels. Good luck.
jagmandan is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-14-2019, 02:01 PM   #4
MJC12
My Ride: 2001 330i
Transmission: 5 Speed
If the wheels were different sizes then the tires would be too so you can just read the tire size. If those are the same all around then you're set. Additionally, like others mentioned, the wheels themselves have markings on them for width and offset.
2001 BMW 330i
2004 Subaru FXT
MJC12 is offline   Reply With Quote
Old 08-16-2019, 10:48 PM   #5
jmo69
My Ride: 03 325xi 98 328is
You can run staggered wheels without a problem, you just need to make sure the outside diameter of the tires are within 2% of each other. You can find the specs on most of the online tire dealers websites.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
