Rough Idle and Loud clacking noise - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-16-2009, 06:29 PM   #1
beemer5
My Ride: E46 323i SE
My E46 has just covered 222,000 miles and its been free of major issues, however today it decides to misfire which clears itself and then returns, so I get the scanner on it and there are no faults coming up, whilst checking it there is a loud clacking noise which is similar to a bolt flying around the flywheel housing [ just a single clack every so often], our thoughts are pointing towards the ccv under the manifold as there is a fairly loud suction noise, which disappears if you pull out the oil dipstick a couple of inches. The vacuum at the oil filler cap is mild which I think is correct. Any ideas folks?
Sean
beemer5 is offline   Reply With Quote
Old 04-16-2009, 06:34 PM   #2
Solidjake
Shifting
Solidjake's Avatar
My Ride: 2013 328i 6MT
Do you think maybe the cracking sound is the DISA? Check my vid on how to disconnect the DISA valve
Old 04-16-2009, 07:02 PM   #3
beemer5
I disconnected the DISA whilst running and it did not appear to make any difference. The clacking noise which incidentaly dissapeared [I think] as on my journey home this evening from the office, some 22 miles I cannot recall hearing anything!.
It seems to come from somewhere below the inlet manifold which suggests to me possibly the ccv. There is definitely a suction noise from the same arae but as yet I have not been able to pinpoint it.
Update; Well on Saturday morning I purchased a new ccv and various hoses, I set about replacing the valve assembly by removing the inlet manifold, completed the job late afternoon, car started immediately but feels down on power a little, also with ignition on you can hear the idle control valve buzzing, so I removed to see what could be wrong, the rotatinf flap is open and there is around a 1.5mm gap. Put it back and it still buzzes, also it seems down on power/acceleration and also stalls when coming to stop at junctions etc. Does it need a new idle control valve?
