Temperature sensor flipping out - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-02-2019, 07:44 PM   #1
lyrad1000
I have a 2004 330ci with 88k miles on it. Once in a while, usually once every few hours of driving, the temperature alarm goes off repeatedly with readouts of "+50.0", and then "-40.0" I'm pretty sure this is Celcius, although I swear I had the display set to F, since way back when the temp alarm worked correctly, I remember it would beep at 37F. Needless to say, this alarm is happening in very mild weather (60F, cloudy weather) and mild driving conditions.
I assume this is just a broken thermostat somewhere.
Is this a simple enough fix? Or should I just send it over to the dealership?
Thanks for any advice.
lyrad1000 is offline   Reply With Quote
Old 12-02-2019, 07:56 PM   #2
Spannerhead
My Ride: '02 330i/5 slicktop
The outside air temperature sensor for the OBC is located in the left side fender liner, right behind the bumper. Check to make sure it's intact and plugged in first.
It's not a common failure item. If the sensor is busted or the wiring is torn up, you can get one from a local you-pull-it yard for peanuts.
Current:
Past BMWs:
Past Other: '85 GSL-SE '88 JZA70 '86 4K quattro '85 RX-7 S '85 RX-7 GSL
Spannerhead is offline   Reply With Quote
Old 12-02-2019, 09:25 PM   #3
Archbid
My Ride: 330ci Convertible
Year: 03
Transmission: 5-Speed Manual
Probably frayed wire or busted connector. Post above is spot on
Archbid is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-02-2019, 10:42 PM   #4
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
I used this sensor repair kit last time mine went AWOL.
https://www.amazon.com/dp/B007H8DIG6/
BaliDawg is online now   Reply With Quote
