No parasitic drain but battery drains voltage after a while, bad alternator? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-09-2019, 04:57 PM   #21
caliber666
My Ride: E46 323i
Originally Posted by Sapote View Post
But whenever it failed the battery light on dash should turn ON; OP didn't say ever seen the battery light.
Alternator is easily tested: let engine idling, turn on headlights and if no battery light then it is still good.
Yea, battery lights doesnt come up and never did
I think light should come up when ur alternator is just dead, 0 charge to battery
I mean alternator can work but badly. so it doesnt show battery light?
caliber666 is offline   Reply With Quote
Old 12-09-2019, 05:09 PM   #22
jmo69
My Ride: 03 325xi 98 328is
I'd do the voltage regulator and see what happens with the voltage levels. My car shows 14.1v a minute or so after startup on OBD Fusion and <12.5v before starting. Never fails me in even the coldest weather. All this talk about needing high voltages to start these cars confuses me. My work truck has a 12L Cat and the alternator runs between 13.1-17v and keeps 3 batteries charged without engine speeds above 2100 rpms.
When I had alternator issues on my xi the battery light never came on either, the last time the battery voltage was down to 10+v.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 12-09-2019, 05:19 PM   #23
bmwTuner1
My Ride: Bmw, 330ci
My light never turned on when I had the same issue
bmwTuner1 is offline   Reply With Quote
Old 12-11-2019, 03:02 PM   #24
2002too
My Ride: '05 325xiT, '72 2002
Maybe irrelevant, but...
Have you had any issues with your Climate Control, as in random speed fluctuations, lack of ability to get full speed, or anything else that just seems weird? When the FRU goes bad one of its manifestations is a random battery drain. Sometimes itís fine, sometimes it leaks a little, some mornings your battery is stone dead. I have replaced several over the years and itís manifestations of failure are never exactly the same each time. It has happened often enough I keep a spare on hand.
2002too is offline   Reply With Quote
Old 12-11-2019, 03:57 PM   #25
caliber666
My Ride: E46 323i
Naah, not really. Everything is fine except my A/C dont work but that not a big deal for me
Old 12-13-2019, 10:32 AM   #26
caliber666
My Ride: E46 323i
Changed brushes today. So old brushes were very short which needed replacment 100%. Seems like they were never changed
My dad had plenty of brushes collected for years. Choosed which will fit better and solderen in.
1st. startup not much difference, but voltage seems little bit higher and stable.
2nd startup everything was great, dash test showed 14.2 without load. With load something like 14, dont remember exactly, but it was good
3rd startup again in old boat. While driving with lights, music, climate control on low speed, dash test shows 13.0-13.1 volts everytime. Heavy load: music, max fan speed, interior lights, highbeams with lowbeams and blinkers, drops to 12.7v
Gonna check brushes again tomorrow. What could happen? Everything seemed ok and then suddenly again, maybe even worse?
Old 12-13-2019, 11:46 AM   #27
Archbid
My Ride: 330ci Convertible
Year: 03
Transmission: 5-Speed Manual
There is more to a regulator than the brushes. For $30 I'd replace the whole regulator (if Bosch)
Archbid is offline   Reply With Quote
Old 12-13-2019, 12:25 PM   #28
caliber666
My Ride: E46 323i
Mines Valeo and those are more expensive I think.
Old 12-13-2019, 01:24 PM   #29
Archbid
Year: 03
$88 with a lifetime warranty isn't bad. At some point your time is worth something, and having the problem done for under $90 seems like a reasonable deal.
Old 12-14-2019, 01:39 PM   #30
caliber666
My Ride: E46 323i
Reporting in again. Found problem with lot of experiments.
My positive cable right at trunk causing all those low voltage problems.
When I lift up positive terminal cable it jumps to 14v. Also cable heats little bit right at that metal thing (black arrow in photo)
Where white arrow is, cable seems crooked and swollen, basically damaged.
What fixes u guys can suggest besides spending 500$ on repair kit for cable?
Image for understanding, not my photo tho and ignore red arrows!https://prnt.sc/qaul3r
Old 12-14-2019, 01:47 PM   #31
bonestockE36
My Ride: 2002 330i auto
Sounds like the explosive terminal triggered.
bonestockE36 is offline   Reply With Quote
Old 12-14-2019, 01:59 PM   #32
caliber666
My Ride: E46 323i
Yes, I think it was blown before me and someone just stucked cable back there
Old 12-14-2019, 06:37 PM   #33
Archbid
Year: 03
Little trip to the pick and pull with cable cutters and it sounds like you are in!
Old 12-18-2019, 06:15 AM   #34
smithpatrick
My Ride: 1999 328is,2001 325i
When the regulator brushes wear past the halfway point, its time for a change!
This can cause drain and low output due to brush spring limit.
smithpatrick is offline   Reply With Quote
Old 12-18-2019, 08:47 AM   #35
caliber666
My Ride: E46 323i
Yes, my brushes were pretty worn.
I already fixed my low voltage problem tho. Getting 14v at battery now
