2002 330xi Acceleration Vibration - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 12-30-2019, 08:22 PM   #1
will.chris78
My Ride: 2002 330xi
Year: 2002
Model: 330xi
Transmission: Manual 5 Speed
I need help with identifying the cause my acceleration vibration in my 2002 330xi with 99k miles; specifically under load. It feels like drivetrain vibration, but very difficult to pin down. The vibration existed previous to the following parts being installed, and still exists.
Replaced:
Motor Mounts
Front axles
Front Control Arms/Bushings
All Struts/Brakes/Springs
All Rotors/Brakes
Clutch/Flywheel
GUIBO
Center Support Bearing
Front and Rear Diff Fluid
Manual Transmission Fluid
Transfer Case Fluid
Alignment
New Tires/All Wheels balanced
The driveshafts appear to be in great shape with no slack in the U-joints. I only replaced the GUIBO and CSB because I had it apart; they were not bad. Any insight would be greatly appreciated.
will.chris78 is offline   Reply With Quote
Old 12-30-2019, 11:27 PM   #2
jmo69
My Ride: 03 325xi 98 328is
The only time I had a vibration under load it was the left front axle but you've replaced both. IDK if the T-case mount would cause any of that. Can you get it on a lift and try to duplicate the vibration, you might be able to better isolate the source.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 12-30-2019, 11:48 PM   #3
wfx32
My Ride: AWD
Model: 330XI 08/2004
Transmission: auto
that's a good idea. i watched the local independent here diagnose a similar problem with his assistant running the car from up on the lift. they found a rear driveshaft problem in no time.
wfx32 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-31-2019, 12:57 AM   #4
ti3int3rc3ptor
My Ride: 2004 330xi 6MT
What is the condition of the driveshaft u joint?
ti3int3rc3ptor is offline   Reply With Quote
Old 12-31-2019, 09:57 AM   #5
will.chris78
My Ride: 2002 330xi
Year: 2002
Model: 330xi
I forgot to mention the transfer case mount was also replaced. I don't have access to a lift, but I'm thinking of setting up a camera under the car.
Old 12-31-2019, 10:02 AM   #6
77'911
Is the vibration coming through the steering wheel or chassis?
regards
77'911 is offline   Reply With Quote
Old 12-31-2019, 10:09 AM   #7
will.chris78
My Ride: 2002 330xi
Year: 2002
Model: 330xi
The vibration is in the chassis and is not felt in the steering wheel.
Old 12-31-2019, 10:09 AM   #8
MissileMech
My Ride: 540i/6
Dual Mass Flywheel failure? It is known to happen. ** nevermind, re-read your list. Driveshaft is all I can think of att.
MissileMech is offline   Reply With Quote
Old 12-31-2019, 10:10 AM   #9
will.chris78
My Ride: 2002 330xi
Year: 2002
Model: 330xi
I have a new clutch and flywheel (single mass).
Old 12-31-2019, 10:19 AM   #10
MissileMech
My Ride: 540i/6
The rear half-shafts could also be the culprit. I had that problem with my 540i but the mileage you have doesn't seem to support that theory. Have you had a compression check? You may have a weak cylinder that can cause a vibration under load.
Old 12-31-2019, 10:29 AM   #11
77'911
The 3 culprits I'd look at:
1) drive shaft
2) front axles(yes, I know they were done. some after market units are not well balanced or go bad early on)
3) single mass flywheel (these cars were intended for the duel set up to reduce vibrations).
regards
Old 12-31-2019, 02:23 PM   #12
will.chris78
My Ride: 2002 330xi
Year: 2002
Model: 330xi
As previously stated, this was happening prior to these parts being installed. All maintenance outlined above has been done in the past 60 days.
Old 12-31-2019, 11:42 PM   #13
MissileMech
My Ride: 540i/6
My 330 had an acceleration vibration and we thought it was drive train, did everything you did, and it turned out to be a weak cylinder. I ran 50/50 high mileage synthetic and diesel oil for several thousand miles and it fixed the issue. Check the vacuum lines at the back of the intake, if leaking they can cause a lean condition in the rear cylinders causing the rings to coke up.
Old 01-01-2020, 07:02 AM   #14
swissrock
My Ride: e46
Year: 2004
Model: 330xi T., 330ci Cab.
My 330xi also suffert from acceleration vibrations, the diagnosis was not easy and after changing lots of other parts it finally was the rear drive shaft.
For some unknown reasons the rear drive shafts of the xi's can get unbalanced, don't know why but it's kind of common.
To fix it you can either get yours re-balanced from a specialized shop or get a used one which is still balanced. This is what I did and it worked for me.
The old unbalanced driveshaft was still in an optical good condition, the u-joint was fine, but it was the cause of the vibrations during acceleration.
swissrock is offline   Reply With Quote
Old 01-26-2020, 08:32 AM   #15
AKA
My Ride: 330xi
Was the vibration there when you bought it or did it develop while you owned it and if so was it after some other work?
I ask because I made the mistake of putting my failing csb back in the way I found it. (The PO had put it in backwards). Also, if the driveshaft was split to replace the CSB, and the orientation of the halves were not marked, it could have been put back wrong and out of balance.
AKA is offline   Reply With Quote
