ssh..ssh...ssh from under center of car? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 12-14-2019, 10:57 PM   #1
Mike.jones
My Ride: 2004 325xi
Year: 2004
Model: 325xi
Transmission: 5 speed
Looking for suggestions. 2004 325xi 5 speed, 177K miles has recently started making an odd noise. Seems to be coming from under the center of the car, varies with road speed and not engine speed. Happens with clutch in or out.
It's a light "sssh" noise. If I were guessing I'd say it sounds like something metal had come loose (exhaust heat shield?) and was resting against the driveshaft, except that it doesn't happen all the time.
It does it probably 70% of the time, but I haven't been able to related anything to when it does or doesn't happen. It sometimes goes away for days at a time, then comes back. It doesn't seem to be getting worse (louder), but I'd rather not wait until it does to figure it out.
Any suggestions? I haven't had a chance to get it on a lift yet, but hope to in the next week or so?
Mike.jones is offline   Reply With Quote
Old 12-15-2019, 11:08 AM   #2
77'911
You might check your center drive shaft. At first, the way you describe it, sounded like a noisy f-pump/filter. There is a fair bit of shielding under neath these cars. Pretty easy for debris to get stuck up there. You might also check the condition of your motor mounts since these car are so dependent on them. If the drive line has dropped, it can create a whole host of noises/vibrations.
regards
77'911 is offline   Reply With Quote
Old 12-16-2019, 07:50 PM   #3
jmo69
My Ride: 03 325xi 98 328is
Sounds like the heat shielding rubbing on the driveshaft. the screws probably pulled through the material. Get some fender washers to repair the enlarged holes.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
