ABS DSC BRAKE Trifecta - cold start - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-18-2019, 04:55 PM   #1
TopCityBMW
My Ride: 330xi
Cold weather snap here with 10-20 degrees Fahrenheit. Brake fluid flushed and filled at stealership about 6 months ago. Got the ABS DSC BRAKE trifecta that stays on for about 15 seconds and then off. What to check? Thoughts?
TopCityBMW is offline   Reply With Quote
Old 12-18-2019, 09:34 PM   #2
dlmrun2002
My Ride: 325xit
Start car and turn steering wheel all the way to the left then all the way to the right. See if that helps.
dlm ny country
dlmrun2002 is offline   Reply With Quote
Old 12-19-2019, 11:28 AM   #3
77'911
How old is the battery? Have you checked to see if there are any codes?
regards
77'911 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-29-2019, 01:43 PM   #4
TopCityBMW
My Ride: 330xi
regards
The battery is one year old. I have not checked for codes. I need to get my XP laptop setup...
Curiously, the headlights cut out briefly when the passenger seat heater was turned on couple days ago. And, the radio and instrument cluster reset twice thus zeroing out trip and mileage computer.
Sent from my iPad using Tapatalk
Old 12-29-2019, 01:44 PM   #5
TopCityBMW
My Ride: 330xi
dlm ny country
Can you explain what turning the wheel will accomplish? I am learning...
Old 12-30-2019, 12:35 AM   #6
77'911
I`d check the battery with a voltmeter along with the cells. Worth also cleaning the ground connections(neg cable, eng ground cable, etc..). I just use an old Peake reader(SRS and a regular DTC reader from them) for our xi which has worked out quite well.
We had a so-so battery in our xi which I upgraded to a 800cca NAPA AGM unit. It got rid of a lot of electrical isms with the car.
regards
Old 12-30-2019, 02:04 AM   #7
TopCityBMW
My Ride: 330xi
regards
Iíll start there. Thanks!
