Will the engine, transmission and transfer case go in from above? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 01-11-2020, 02:52 PM   #1
TobyB
My Ride: 2004xit, 2001ci
It's the high- mileage E46 saga: Start fixing one thing, and pretty soon, everything's out. For $35 worth of seals and o- rings...
So: can the assembled engine, trans and transfer case drop in from above?
It very much looks like the front subframe is in the way, but getting the whole
car high enough to put it in from beneath is a bit scary with my current resources.
The other option (which is what I'll probably do) is lower the subframe, fix the
oil pan gasket and o- rings, then lower the engine somewhat to reattach
the transmission. Lift the engine, then lift the subframe.
But that's a lot of uncomfortable under- the- car time.
t
cramped for space due to my own lack of planning.
Really. It just needs a clutch!
"I'm sorry. I actually had to poop and ended up breaking the car."
- Hot Tub
TobyB is offline   Reply With Quote
Old 01-14-2020, 01:21 AM   #2
jmo69
My Ride: 03 325xi 98 328is
This is just a guess but if you pull the radiator and support out you won't have to lift it as high. I think it involves drilling out some spot welds to remove the support. You can bolt it back in.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
