M54 Oil Pump solution - Page 4 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
Old 06-20-2011, 11:12 AM   #61
DET330ci
My Ride: 2001 330ci 5MT
what a great thread subsribed for sure
DET330ci is offline   Reply With Quote
Old 06-21-2011, 11:43 AM   #62
TerraPhantm
My Ride: M3
Is this an M54B30 specific issue? Or do other BMW engines (S54 for example) suffer from the same issue? If the S54 suffers from a similar problem, is there a similar solution? Since the S54 redlines at 8k, I'd be kinda concerned about the long-term reliability of the oil pump if there are similar harmonics prblems
Old 06-21-2011, 01:30 PM   #63
aggieE46
Keep it clean
aggieE46's Avatar
My Ride: 03 Evo, 07 Passat
I believe it's M54, although I THINK the S52 had similar harmonic issues (due to the crank).
The S54 uses a totally different oil pump.
Old 06-21-2011, 03:16 PM   #64
MSportBMW
My Ride: E46 325, EVO8 MR
Just to clarify, so the Bimmerworld M50 Drilled Oil Pump Nut solution should be fine for a semi-track 325?
So essentially just the 3.0L have harmonics issues and require the more expensive solutions previously listed? Kind of making me think twice about doing a 3.0L engine swap...
Thanks for the replies
MSportBMW is offline   Reply With Quote
Old 06-21-2011, 03:57 PM   #65
mrshelley
My Ride: 2004 330i
You could take the stock oil pump nut off and drill it yourself. Takes about a minute.
or
Just Red Loctite it. I run the BMW Motorsport pump and it has a regular old right hand threaded nut on it. I just Red Loctite it and that's it.
Old 06-21-2011, 11:06 PM   #66
TerraPhantm
My Ride: M3
I did some research, and the S52 also seems to suffer from the oil pump nut issue... makes sense since the M54B30 and S52 have the same crank, and S52s actually see higher revs. While doing said research, I also found that the S52 guys often retrofit Euro S50 or S54 oil pans and pumps (while retaining the S52 sprocket so the chain still fits). Is there any reason that cannot be done on an M54?
Old 06-22-2011, 12:46 AM   #67
McSpeed
My Ride: 2005 ZHP TT Stg 1
Yes - clearance. The conrod cap will hit on the 3.0.
Also the S54 pump only attaches at three points which is less desirable in terms of block bracing.
Plus it uses the same failure prone sprocket shaft as the M54 pump.
SOLD but fondly remembered...
Technique Tuning Stage 1 Turbo w/ Greddy Profec B Spec II | 3.07 Quaife
ATI Super Damper | Vaio Oil Pump | VAC Pan Baffle | SRE Organic Clutch
Turner Reinforcements | SPC Camber Arms | Powerflex FCABs & SFBs
Turbo Driveability Video
Horsepower vs. Torque
McSpeed is offline   Reply With Quote
Old 06-22-2011, 01:45 AM   #68
MSportBMW
or
Thanks for the help
I was sweating with the thought of having to buy the BMW Motorsport solution as it cost as much as a used 3.0L motor
Old 06-23-2011, 11:29 AM   #69
bigjae1976
bigjae1976's Avatar
My Ride: 2011 E90 M3
If I get the Greg Smith pump...why would I need to remove the sprocket?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola red
Old 06-23-2011, 11:56 AM   #70
McSpeed
To mount it; otherwise you can either get it located on the dowels, or chained up, but not both.
Old 06-23-2011, 12:23 PM   #71
TxZHP04
My Ride: ESS TS2+ ZHP
Yeah, there's no tensioner for the oil pump chain hence not much slack in the chain to work with.
For Sale DFW area: 04 IR 330i ZHP | 167k mi | ESS TS2+ SC (needs TLC and better tune) | MagnaFlow "headers" (cats shot, won't pass OBDII) | KMS 3.64 LSD | AST 4100 550/650 (needs new dampers)| APEX ARC-8 18x9 | H&R front sway bar | Vorshlag camber plates, RTAB limiters | TMS subframe & swaybar reinforcements | UUC SSK & DSSR | UUC TM & TME | BW motor mounts | Dinan strut & shock tower bars | vaio 4-bolt oil pump | AC leak, needs evap
Old 07-12-2011, 06:13 AM   #72
phamine
My Ride: 01 Orient Blue 330i
Send a message via AIM to phamine Send a message via Yahoo to phamine
Glad I found this thread. This is the best solution as it seems the multiple bolts would distribute the load off the oil pump nut.
phamine is offline   Reply With Quote
Old 11-12-2011, 01:13 PM   #73
notaduc
My Ride: e46m
Is the shaft heat treated and centerless ground? I have heard of issues with aftermarket shafts that are just turned on a lathe. Also what alloy is it?
notaduc is offline   Reply With Quote
Old 11-12-2011, 01:17 PM   #74
notaduc
My Ride: e46m
Anyone ever safety wire the VAC bolt?
Whoops, NVM, just saw that post.
Old 12-07-2011, 10:07 PM   #75
yahweh
My Ride: e30 ix, e34 touring
Originally Posted by Bimster View Post
Sounds exactly like what happened on my '04 530i at about 70k. The red oil pressure light would come on for a few seconds after: long drive, idle, starting up again slowly. (Panic time when going up a one way parking garage ramp helix with no exits.)
The dealer replaced the sender first and ultimately ended up replacing the oil pump.
Oil pump pressure is proportional to engine speed, so if there's a problem developing it will likely appear first at your lowest speeds when the oil is really hot and then disappear as the engine speeds up.
I Believe there was a TSB on that on the earlier cars.
Does anybody have a photo of the motorsports pump?
yahweh is offline   Reply With Quote
Old 12-30-2011, 07:12 PM   #76
flashmeow
Banned User
My Ride: E30-E46-E90-E90M-F30
dont mean to bring up and old thread but since I am inspecting my nut soon I just saw that the ZHP (performance package) has its own upgrade nut (11417897238). Maybe this is a more cheaper solution.
Old 12-30-2011, 07:32 PM   #77
aggieE46
Keep it clean
aggieE46's Avatar
I think it's been confirmed that it just has factory loctite on it. Still doesn't keep the sprocket from sheering off
Old 01-01-2012, 11:00 PM   #78
da Vinci
My Ride: 2003 BMW 330i ZHP
Has anyone looked into machining the shaft and sprocket as one solid unit?
Having never remove or install this oil pump. Do you need the sprocket off to install the chain?
Click here for my Build Thread
"Make everything as simple as possible, but not simpler." Albert Einstein
da Vinci is offline   Reply With Quote
Old 01-02-2012, 08:18 AM   #79
Grande D
My Ride: E36 M3
Apparently ZHPs have had this failure on tracks. I think the consensus is that the ZHP will need more provocation to have the nut fall of, because it is "locked" from the factory- such as holding it over 6k RPM on a spirited drive for an extended period of time, on the track or off. It seems normal 330s are much more prone to this failure even under normal hard driving. Keep in mind the ZHP also has a higher redline, which could make this problem worse (re: harmonic problems).
Yes, or the BMW, tan beige version. There is a picture somewhere, it is some type of fastener lock, whatever the compound is. It comes already "lactated"
It will change your life!
Old 01-18-2012, 09:29 PM   #80
flashmeow
Banned User
PEI330,
I remembered reading your build thread on here and my330i that your oil pump nut was finger loose even after the special modified oil pump and ATI damper. You discovered this observation after your engine exploded and you disassembled your engine. If this is correct then is there really any cure for the oil pump nut?
