Almost ZHP nachtblau 330i - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
The Showroom
Old 11-16-2018, 11:32 AM   #21
jarjar
My Ride: 04 BMW 330CI
It's so beautiful. Looks great. Did you notice any difference with strut reinforcement plates?
jarjar is offline   Reply With Quote
Old 11-16-2018, 01:02 PM   #22
leonidas
My Ride: Bmw 330i
Thank you. I do not feel the difference to be honest but the main purpose of them is to prevent deformation or even breaking of the strut tower which commonly happens when driving often on bumpy roads, or hitting pot hole mostly in combination with stiffer sport suspension.
leonidas is offline   Reply With Quote
Old 11-18-2018, 02:16 AM   #23
JohnnyAndrews
JohnnyAndrews's Avatar
My Ride: 99' BMW 323i
Very clean man! GLWS
JohnnyAndrews is offline   Reply With Quote
Sponsored Links
Advertisement
Old 11-18-2018, 09:31 AM   #24
leonidas
My Ride: Bmw 330i
Thanks but I hope nothing like that happens in near future
Old 11-18-2018, 09:42 AM   #25
leonidas
My Ride: Bmw 330i
Undercarriage project finished finally. Front fender lines uncovered, few pounds of soil from behind them was brushed away with various types of brushes including paint brush, tooth brush and old trusty apple tree branch. Every slight indication of rust sanded and repainted. Then fluid film again. That thing smells! I planned to spray it into doors and trunk cavities but I has changed my mind. It can be smelled in interior after spraying the undercarriage alone. I cannot imagine what it would be if I kept with the original plan. Reinforcement brace reinstalled using new screws torqued-to-yeld exactly as is said in repair manual.
ID:	761287   Click image for larger version
ID:	761289   Click image for larger version
ID:	761291   Click image for larger version
Old 11-18-2018, 01:00 PM   #26
Antti
My Ride: 330CI / 316 1.8i
Year: 2005
Model: 330CI M-Sport II
Transmission: Automatic
Good work there, that sill cleaning/painting project is like from my winterbeater thread.
Really important to clean places, sand + paint and protect.
Btw you are the first person i know who replaces reinforcement plate bolts. I would say it is really good thing.
Maybe i buy new set of bolts for coupe when i install reinforcement plate back.
No rush yet, we have 5-6 months winter left..
BMW E46 330CI M-Sport II 2005 Individual Black Sapphire metallic /Showroom
BMW E46 316 1.8i Sport 2005 Mysticblau metallic /Showroom
Renault Clio RS197 2007 Ultra Red
Antti is offline   Reply With Quote
Old 01-20-2019, 07:12 AM   #27
leonidas
My Ride: Bmw 330i
Decided to use this cold winter time to maintain my maintenance a little bit. I Cleaned ratchets and lubricated with lithium grease, cleaned bits and nuts with brake cleaner and protected with WD40. If you buy similar tool set do not make the same mistake I did and coat everything. Even though it is chrom-vanadium, insides of nuts developed small rusty spots, not talking about steel bits.
ID:	766447   Click image for larger version
ID:	766449   Click image for larger version
ID:	766451   Click image for larger version
Old 01-20-2019, 07:47 PM   #28
reiseman
reiseman's Avatar
My Ride: needs a garage
Year: 2004
Model: 330ci, 02 325it
Transmission: 6speed
You have an awesome looking car. Very nice mate!
reiseman is offline   Reply With Quote
Old 01-31-2019, 09:13 AM   #29
lllRazorlll
lllRazorlll's Avatar
My Ride: Accord Coupe
Nice car
lllRazorlll is offline   Reply With Quote
Old 04-01-2019, 04:38 AM   #30
BLAMM0
My Ride: 325i, Audi Coupe
Nice car, any possibility to record the sound of the exhaust system?
BLAMM0 is offline   Reply With Quote
Old 12-20-2019, 07:43 AM   #31
leonidas
My Ride: Bmw 330i
I have gone through really bussy period so I have not updated the thread for some time but now is time to fix it
Old 12-20-2019, 08:12 AM   #32
leonidas
My Ride: Bmw 330i
After buying scan tool I found this very unpleasant code when scanning transmission. The highway driving test at 80m/h proved the issue when instead of 2750 rpms engine kept almost 3000 rpms. No other symptoms. After a bit of searching I realised that it is another common problem. BMW documented it and even published the bulletin adressing it. The gasket inside the converter deteriorates and lets the oil to flow inside. Slipping then overheats the oil and thins it down over time and also contaminates it with metal shawings. Otherwise good transmission is then destroyed. And because the transmission must have gone out of the car it was rebuilt also. At the beginning I thought that the rpm shift was the only symptom but after the repair I could say that I feelt performance increase also. Moreover, the guy rebuilding it confirmed that all the parts he replaced were in condition equal to the car mileage which proved that the mileage was not tampered.
Old 12-20-2019, 08:51 AM   #33
leonidas
My Ride: Bmw 330i
When I started to smell fumes in the cabin I prepared myself for a big gasket mission because from my previous experience with these engines I already knew that around 120 000 miles (200 000km) most of the engine gaskets are failing or about to fail. I replaced valve cover gasket (Victor Reinz), Valve Cover Washers (Febi Bilstein), oil filter housing gasket (OEM), oil filter cap (Vaico), VANOS hose (Meyle). When being there VANOS was resealed with Mehenker kit. If someone is considering buying this kit I recommend buyng new OEM plastic sealing plugs because gaskets in this kit are too big and I could not use it. Spark plugs were replaced for classic NGK sparks according to specification.
Old 12-20-2019, 02:59 PM   #34
leonidas
My Ride: Bmw 330i
These cars are real attention seekers and so is mine. Not long time after, one of the rear brakes got stucked so I rebuilt both rear calipers. Hoses were replaced for TRW ones and at the end brake fluid was changed for ATE SL.6 DOT4.
Old 12-25-2019, 09:14 AM   #35
leonidas
My Ride: Bmw 330i
When I can have a rest after a lot of work on the car I keep myself busy thanks to my clumsiness. Hitting a curb is always painfull experience but in this case it hurt double because the previous owner had the wheels refurbished in very beautifull colour. I was always scared to scratch them because they are painted in slightly blue silver. When trying to find matching colour I spent about 20 minutes kneeling down with about 50 samples of silver but in the end I think I made it. When being aware of repair being done and looking very closely it can be seen but for most people just standing next to car it is invisible so I am satisfied with myself
Old 12-27-2019, 07:06 AM   #36
leonidas
My Ride: Bmw 330i
After 8 months from when I adressed the rust on the undercariage with Hammerite and Fluidfilm I went down to check the damage the winter had caused and to my surprise there was almost no rust. I did not trust so much in Hammerite but I was hyped by all the good reviews on Fluidfilm and now I can say it is all true. The only rust spots I found were on the top of the half shafts (because I did not turned the wheels when treating them), and on the frame that goes under the diff because I scratched the paint away when using this part as a jacking point. There still were traces of the fluidfilm in deeper areas where water does not splash from wheels. After the check I happily reapplied another layer for this winter. In future, I will probably invest money in their spray gun and will be using more thicker formula of fluidfilm that protects better and lasts longer than spray can version.
After reapplication...
[img][/img]
Old 12-30-2019, 01:09 PM   #37
leonidas
My Ride: Bmw 330i
When preparing for winter I did not forget about clearcoat as well. Car was washed with ValetPRO Concentrated Car Wash, all previous coatings were stripped off with Carpro Eraser and then coated with Soft99 Fusso Coat 12M Dark. During summer I usually use Collinite Marque D Elegance 915 for its deep glossy finish but for winter I prefere Fusso because it lasts much longer and beeds water like noone else. On front bumper, hood, roof and trunk lid it lasted for 5 months last winter. On rear bumper, side skirts, and doors especially behind wheels the wax was dead much sooner of course.
Old 01-10-2020, 01:01 PM   #38
TRITONAL
My Ride: E46, F25
Gorgeous car, and love the thread. Keep it up!
The E46s are the Knights of the chessboard. They can outmaneuver the other, more powerful pieces on the board. They aren't the King or Queen of the garage, but they are the first piece that you want to move.
TRITONAL is offline   Reply With Quote
Old 01-12-2020, 05:33 AM   #39
Antti
Year: 2005
Car looks as great as always.
Many people also in Finland use Fusso in wintertime.
Old pictures are not working?
