E46 COOLING SYSTEM GUIDE - overheating/coolant/etc - Page 11 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 423 votes, 4.67 average. Display Modes
Old 05-14-2012, 10:59 AM   #201
Stinger9
My Ride: '04 330Ci
Your coolant loss is too high and if you have any indication that the radiator is leaking, we just replace them in the US because they are only $150 here.
Old 05-14-2012, 07:46 PM   #202
fatboyx9
My Ride: 325Ci 330i
Anyone ever try using a expansion tank cap off a 2001 Land Rover? The Rover has a lower psi rating and fit's perfect.
fatboyx9 is offline   Reply With Quote
Old 05-14-2012, 08:10 PM   #203
Zell
Zell's Avatar
My Ride: so turbo wow
They look to be made by the exact same manufacturer. Would a lower psi rating benefit anything? It'd keep the system under less pressure, meaning that it will have a lower boiling point. Would it preserve the expansion tank longer? The only worry I'd have would be overheating.
BMW: 30 PSI
1999-2004 Land Rover: 15 PSI
You may be onto something here if it prolongs the cooling system life; however, BMW chose 30 PSI for a reason. We all know how hot our engines run, it may be that the Range Rover engines run cooler.
By using a 15 PSI cap, you are effectively reducing the boiling point by about 37 degrees F. Note that this does not take into account the increased boiling point properties that the anti-freeze adds, too, which is not much (~15 degrees F).
What is the normal operating temperature of our engines?
Sponsored Links
Advertisement
Old 05-14-2012, 08:20 PM   #204
Blocked Out
My Ride: Diesel
Zell, you obviously didnt read any of my posts on the cap.
Original BMW Teile ///
IMG_1725
Old 05-14-2012, 08:22 PM   #205
Zell
Zell's Avatar
No sir I did not.
Old 05-14-2012, 08:29 PM   #206
Blocked Out
My Ride: Diesel
Post #23 , #32
IMG_1725
Old 05-14-2012, 08:30 PM   #207
fatboyx9
My Ride: 325Ci 330i
The Range Rover doesn't run at a cooler temp, i've ran the lower Rover cap for a year now on both my bimmers
Old 05-14-2012, 08:32 PM   #208
TerraPhantm
My Ride: M3
It would have to be 15psi relative to the atmosphere wouldn't it? Meaning that the absolute pressure would be about 30?
TerraPhantm is online now   Reply With Quote
Old 05-14-2012, 08:45 PM   #209
Zell
Zell's Avatar
Meh, worth a shot. I might just pick one up. Only 11 bucks. But with the improved expansion tank...is it an issue anymore?
Old 05-14-2012, 08:49 PM   #210
fatboyx9
My Ride: 325Ci 330i
Went back and read your post Blocked Out,, AMEN!!!
Old 05-14-2012, 09:08 PM   #211
Blocked Out
My Ride: Diesel
I gotta be honest , Im not very good with these terms. All I know is that whenever our system reaches an internal pressure higher then 2.0 bar / 29psi (200kpa), the caps inner vale would open and the pressure would be released and maintained at 29psi (200kpa)
The other (E30) cap has a rating of 1.4 bar / 20psi (140kpa) and therefore it would maintain the inner pressure of the system at that level.
IMG_1725
Old 05-14-2012, 09:18 PM   #212
fatboyx9
My Ride: 325Ci 330i
Gonna buy the E30 caps tomorrow, THANKS Blocked Out
Old 05-14-2012, 09:21 PM   #213
Blocked Out
My Ride: Diesel
You're welcome, just make sure its the same part number as NOT all E30s had that cap. Check the part number. And when you get the cap make sure it says 140 on the bottom of it.
IMG_1725
Old 05-14-2012, 09:52 PM   #214
Stinger9
My Ride: '04 330Ci
So BMW has engineers with years of schooling just for this topic along with all kinds of test equipment. Also factor in real life testing as I've personally seen a fleet of BMW's wired for instrumentation riding around Death Valley when it was 115 degrees there. They've designed there ET pressure relief cap taking into account all the features of our electrically heated thermostat controlled by the ECM. I'm betting most on here could not begin to explain how and why the heated thermostat works.
But with a little bit of high school physics we're all going to run out and buy an ET cap with a pressure threshold of 1/2 of what came with our cars. Does the term unintended consequences mean anything to anyone?
Really, yes we have ET's that split open once in a while, but for the most part if we keep our systems renewed, we do not need to worry about reengineering our car systems in this instance. It would only take one occasion under unusual circumstances to boil out enough water to perhaps overheat our engines before we have a chance to notice all is not right. I'm keeping my prescribed ET cap.
Old 05-14-2012, 09:53 PM   #215
TerraPhantm
My Ride: M3
I'm not entirely sure if the stated pressures are relative to the atmosphere or if they're absolute. Relative would make more sense to me. A cap that regulated to 1-bar absolutely would effectively be the same as not having a cap at all
Old 05-14-2012, 09:54 PM   #216
Stinger9
My Ride: '04 330Ci
You are correct. Gauge pressure, not absolute.
Old 05-14-2012, 11:50 PM   #217
TerraPhantm
My Ride: M3
In that case Zell's table is wrong - the right column should be shifted down by 1 bar. In which case even the RR cap would allow enough pressure to build to not have to worry about the coolant boiling at normal temperatures
Old 05-15-2012, 12:15 AM   #218
fatboyx9
My Ride: 325Ci 330i
Heaven forbid us dumb high school grads try something the highly paid engineers have all figured out. I haven't found much that can not be improved Stinger, are you an automotive engineer? I could care less for most of them, there's never enough R&D.
Old 05-15-2012, 12:27 AM   #219
My Ride: Lexus
I don't understand the obsession or desire to tinker with systems put into place by actual engineers. BMW engineers at that. Like Stinger said, a well-maintained cooling system means you'll never have a problem.
Blocked out, have you actually measured your coolant temps while driving? I'd suspect a lower pressure cap would lower the boiling point of your water/coolant and thus cause cavitation which would decrease efficiency and run a higher risk of an overheat. Since our gauges are buffered, you could be well near overheating and not even know it.
Personally, I see no need to tinker with the caps. The resources BMW has on all design specification and internal data is well beyond any information we'd ever have.
Complete E46 Info 5.7M VIEWS
Old 05-15-2012, 12:42 AM   #220
Stinger9
My Ride: '04 330Ci
Playing the "I'm really more stupid than you even think card" will not cut it for much. I know you know stuff. And "anyone who pursues learning lots about complex science is an idiot" indicates your respect for education. Your advice therefore is stay ignorant?
Sure I know some stuff can be played around with and even improved. I put in a Stewart pump and poly CAB's and KONI FSD's. But I just urge caution when making snap change decisions around a complex system that none of us completely understand.
Footnote: Engineers are not that highly paid.
bleeding, coolant, cooling system, diy cooling, expansion tank, lower hose sensor, overheat, radiator, radiator hose, temp sensor, temperature sensor, thermostat, water pump
