highly competitive se46 for sale in raleigh - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 06-06-2018, 07:19 PM   #1
jtower
My Ride: spec e46
my 4th build (technically 3.5th but i prefer to round up) is now available for sale. i recently picked up a lovely donor that i'm ready to start building.
2002 orient blue coupe
clean title
purchased from another se46 racer in mid 2017, street driven for a while
build started late 2017, first race march 2018
engine
just replaced the motor with one from a 120k automatic donor (documentation available)
all external seals and gaskets replaced, no leaks at all
no power steering leaks either, which isn't often the case
just ran three days at vir with no visible oil use
csf all aluminum high capacity radiator
all new cooling system components
fully automatic radiator fan
full spec exhaust
spec ecu with ews delete
driveline
bimmerworld solid motor mounts
bimmerworld solid trans mounts
bimmerworld race shifter
bimmerworld race shift knob
new shift linkage bushings and coupler
tilton race clutch and flywheel
bimmerworld adjustable clutch stop
new guibo
fresh redline trans oil
interior/safety
custom cage by competition cages
interior painted by rocky's auto body
full sfi cage padding for driver
nrg steering wheel quick release
320mm steering wheel
sparco pro-adv ts seat
sparco endurance harness
bimmerworld matrix style seat mounts
motion motorsport infinitely adjustable side mounts
lifeline 4 liter fire system w/ dual pulls
panoramic rearview mirror
fia rear rain light
dash secured using factory mounts, very secure
custom center dash panel for aim solo and electrical switches
exposed wiring wrapped in conduit
ioport window net with straps, no lower bar required, easy one hand operation
chassis/diff
bimmerworld solid rear subframe bushings
bimmerworld solid diff bushings
diffsonline spec e46 race diff
bimmerworld welded rear subframe chassis reinforcements
fresh redline 75w110 diff oil
weight reduction
heater core removed and plugged
wiring significantly thinned
doors are totally gutted and completely removable
fiberglass sunroof fill panel
interior brackets cut out
trunk lid skinned
manual trunk latch
car weighs just over 2600# with 1/2 fuel load
still has a full size battery, charcoal system, side glass, etc so there's another 40-50# available if desired
suspension
spec mcs shocks
spec hypercoil springs
zhp front control arms
powerflex offset fcabs
ground control race camber plates
bimmerworld shock tower reinforcements
hotchkis front and rear swaybars
bimmerworld adjustable race endlinks
ground control adjustable rear spring perches
ground control rear spring hats
powerflex rtabs
bimmerworld adjustable rear camber arms
bimmerworld spherical rear shock mounts
brakes/wheels/tires
bimmerworld race studs
bimmerworld forged wheels 17x9 et42 with 255 toyo rr
oz lightweight wheels 17x8 et40 with toyo 235 ra1 (wets)
pfc08 front, pfc332 rear pads
zimmerman rotors
fresh ate200 fluid
10mm front spacers
misc
new windshield
front and rear tow hooks
vinyl numbers and class stickers
aim solo dl hardwired for both power and canbus
dual cigar lighter power outlets for camera/radio
transponder power circuit wired to ignition
plenty of room to install passenger seat
can include radio system, coolshirt, and/or helmet blower if desired
multiple wins wet and dry, fast lap of 208.4 at vir (0.1s off lap record)
the car has had a couple of minor on track incidents resulting in some incidental body damage all of it is cosmetic and the car is 100% raceable as is. the LR quarter is pushed in in front of the rear wheel, the hood is slightly kinked on one corner, and the RF fender has a small wrinkle. the front bumper is scraped up but fully structural and functional, would be a good candidate for a cheap ebay m3 replica bumper.
priced for quick sale at $32,500 as it sits including the aim solo dl and a set of forged wheels in ready to race condition, or 32k without the seat if you don't want the pro-adv. if you would like me to take care of any of the cosmetic issues prior to purchase i'm happy to discuss options. can deliver within a reasonable distance of raleigh. email [email protected] for more information.
jtower is offline   Reply With Quote
Old 06-06-2018, 07:22 PM   #2
jtower
My Ride: spec e46
pics from a month ago
ID:	745584   Click image for larger version
ID:	745586   Click image for larger version
ID:	745588   Click image for larger version
Old 06-06-2018, 07:30 PM   #3
jtower
My Ride: spec e46
closeups of damage
ID:	745606   Click image for larger version
ID:	745608   Click image for larger version
ID:	745610   Click image for larger version
ID:	745614   Click image for larger version
Sponsored Links
Advertisement
Old 06-06-2018, 07:56 PM   #4
jtower
My Ride: spec e46
cage pics
ID:	745618   Click image for larger version
ID:	745620   Click image for larger version
ID:	745622   Click image for larger version
