slicktop facelift sedan, fully prepped, ready to race - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 10-08-2018, 06:49 PM   #1
jtower
My Ride: spec e46
2002 alpine white sedan
rare slicktop (sunroof delete)
196k miles
engine
all external seals and gaskets replaced
oil pan baffle welded in pan
oil pump nut secured
all new cooling system components
fully automatic radiator fan
full spec exhaust
spec ecu with ews delete
fresh redline 40wt race oil and filter
driveline
bimmerworld solid motor mounts
bimmerworld solid trans mounts
new shift linkage bushings and coupler
jb racing lightweight flywheel and m5 clutch
bimmerworld adjustable clutch stop
new guibo
fresh redline d4atf oil
interior/safety
custom cage by competition cages
cage spray painted gloss white
tilt/telescoping steering retained
nrg steering wheel quick release
omp flat bottom steering wheel
omp hte-r seat (fia cert thru 2022)
sparco endurance harness (fia cert thru 2022)
bimmerworld matrix style seat mounts
motion motorsport infinitely adjustable side mounts
lifeline 4 liter fire system w/ dual pulls
kill switch with ecu interrupt circuit
longacre panoramic rearview mirror
dash secured using factory mounts
custom center dash panel for aim solo and electrical switches
dash trim and airbag cover retained
ioport window net with heim joint pivot
aaf firewall blockoff plate
chassis/diff
bimmerworld solid rear subframe bushings
powerflex diff bushings
diffsonline spec e46 race diff
bimmerworld welded rear subframe chassis reinforcements
fresh redline 75w110 diff oil
weight reduction
heater core removed and plugged
wiring significantly thinned
doors are gutted and removable
all tar removed
interior brackets cut out
aftermarket side mirrors
suspension
spec mcs shocks
spec hypercoil springs
zhp front control arms
bimmerworld race fcabs
ground control race camber plates
bimmerworld shock tower reinforcements
hotchkis front and rear swaybars
bimmerworld adjustable race endlinks
ground control adjustable rear spring perches
ground control rear spring hats
powerflex rtabs
bimmerworld spherical rear shock mounts
brakes/wheels/tires
bimmerworld wheel studs
bimmerworld te:al forged wheels 17x9 et42 with 255 toyo rr
pfc08 front, pfc332 rear pads
fresh ate200 fluid
12mm front spacers
misc
vinyl numbers and class stickers
aim solo dl hardwired for both power and canbus
dual cigar lighter power outlets for camera/radio
transponder power circuit wired to ignition
plenty of room to install passenger seat
radio system and/or coolshirt available at extra cost
fresh build, raced one weekend at vir. ran a 2:08.9 at vir on literally its first hot lap. body is clean and straight, no electrical issues at all, in fact there isn't a single warning light on the dash except for the seatbelt (and that can be coded off). stability and traction control systems are still intact but easily removed and/or disabled if desired. starts immediately hot or cold and idles smoothly, no funny noises or erratic idle speed. engine is shockingly clean and dry but i replaced the major gaskets anyway (i despise leaks). has nasa logbook and 2018 inspection. offered at $36,500 including the aim solo dl and set of forged wheels with spec race tires, please email [email protected] for more information.
jtower is offline   Reply With Quote
Old 10-08-2018, 06:57 PM   #2
jtower
My Ride: spec e46
if pics are not visible they are also available here http://cerient.net/spece46/notb/
Old 11-03-2018, 11:52 AM   #3
jtower
My Ride: spec e46
just installed a set of stickers mounted on brand new forged wheels
Sponsored Links
Advertisement
Old 11-18-2018, 02:49 PM   #4
jtower
My Ride: spec e46
sold
