Race ready SE46 car for sale - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Motorsports & Track Forum > Spec E46 racing class forum
Official Spec E46 racing class forum.
Old 06-08-2019, 07:25 PM   #1
jtower
My Ride: spec e46
2001 stauhlblau coupe
Engine
Replaced in 2016
All external seals and gaskets replaced, no leaks at all
CCV components replaced included a csf all aluminum high capacity radiator
DISA updated
Cooling system components recently replaced
All power steering hoses and reservoir replaced
Manual high capacity SPAL electric radiator fan
Steel mesh covering radiator and brake duct intakes
Spec exhaust
Spec ECU
Bimmerworld fuel starve kit
Driveline
Solid motor mounts
Solid trans mounts
CAE race shifter
New shift linkage bushings and coupler
Tilton race clutch and flywheel
Bimmerworld adjustable clutch stop
Recent guibo and center support bearing
Fresh redline trans oil annually
Interior/safety
Custom cage by OverRev Fabrication (Wilmington NC)
Partial interior paint
Driver side floor cover
Full sfi cage padding for driver
NRG steering wheel quick release
Sparco steering wheel
Sparco pro-adv seat (FIA cert thru end of 2020
OMP harness (FIA cert thru end of 2021)
Motion Motorsport floor mounts
Motion motorsport infinitely adjustable side mounts
Mechanical fire system w/ dual pulls
Bimmerworld dual electric kill switch
Panoramic rearview mirror
FIA rear rain light
Dash bar remains stock and secured using factory mounts
Custom center dash panel for electrical switches
Window net with straps
Center net
Chassis/diff
Solid rear subframe bushings
Solid diff bushings
Diffsonline spec e46 race diff
Welded rear subframe chassis reinforcements
Redline 75w110 diff oil flushed annually
Weight reduction
Heater core removed and plugged
Wiring significantly thinned
Doors are totally gutted
Aluminum sunroof panel
Interior brackets cut out
Manual trunk latch
Polycarbonate side windows
Lightweight battery
Car weighs just over 2600# with 1/2 fuel load
Suspension
Spec MCS shocks
Spec Hypercoil springs
Delrin fcabs
Ground Control race camber plates
Shock tower reinforcements
Hotchkis front and rear swaybars
Bimmerworld adjustable race endlinks
Ground Control adjustable rear spring perches
Ground Control rear spring hats
Turner adjustable rear camber arms
Brakes/wheels/tires
Wheel studs
Apex Arc-8 wheels 17x9
Raybestos pads front and rear
Zimmerman rotors
ATE 200 fluid
10mm front spacers
Misc
Front and rear tow hooks
Vinyl numbers and class stickers
AIM MXL2 with SmartyCam hardwired for both power and canbus
Transponder power circuit wired to ignition
Plenty of room to install passenger seat
Coolshirt system wired to switch in dash
The car has never had any on track incidents resulting in body damage
The car has been driven to a 2:08.3 at VIR, and would have been faster if the car in front hadn't forced me to lift at the end
pics can also been seen at http://cerient.net/spece46/346/
Offered at $32,900 as it sits including the AIM MXL2, SmartyCam, AMB transponder, and coolshirt. Car is in ready to race condition. Can deliver within a reasonable distance of Raleigh, NC. Email jtower at gmail dot com if interested.
jtower is offline   Reply With Quote
Old 06-08-2019, 07:29 PM   #2
jtower
My Ride: spec e46
Old 06-08-2019, 07:35 PM   #3
jtower
My Ride: spec e46
Sponsored Links
Advertisement
Old 06-08-2019, 07:37 PM   #4
jtower
My Ride: spec e46
Old 06-08-2019, 07:39 PM   #5
jtower
My Ride: spec e46
