Xi auto to manual - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 12-11-2019, 02:38 PM   #1
Vader46
My Ride: E46 325xi
Xi auto to manual
so I read the unofficial guide, and just wondering is it the same? or will the transfer case and front and rear diff need to be swapped? have a 5speed xi parts car I got for cheap. did find someone say the shifter bushing bracket was missing on theirs. so I might just cut it off jus tin case.
Vader46 is offline   Reply With Quote
Old 12-13-2019, 12:44 PM   #2
jagmandan
My Ride: E46 325xit -> 330xit
Most of it will be very similar to RWD. The transfer cases are the same between auto and manual. Differentials will have a different ratio but whether to swap is a matter of preference. See this page for info: http://www.bokchoys.com/differential/GearRatios.htm
I don't recall off the top of my head if the driveshafts are different but if you have a parts car you should have what you need regardless.
jagmandan is offline   Reply With Quote
Old 12-16-2019, 09:04 AM   #3
Vader46
My Ride: E46 325xi
ok cool thanks
Old 12-16-2019, 07:28 PM   #4
jmo69
My Ride: 03 325xi 98 328is
The ratios in the auto difs will cause higher rpms at highway speeds but will make for better acceleration. If the manual dif ratios are like the RWD cars they will be around 2.93 and your autos will be 3.46.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
jmo69 is offline   Reply With Quote
