65mph+ vibration/drone - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 01-23-2020, 06:39 PM   #1
Alpinerunner
My Ride: 1990 M3
I have a 193k miles 325xi wagon that has a vibration but it's more of a drone that starts around 60-65mph... I hear it more than I feel it. The front axles were replaced at 133k miles and I just replaced the driveshaft. What is the next most likely culprit? Do rear axles go bad? Could the front CV joints have failed in 60k miles (boots have not failed). I realize it could be the tires, but they are pretty new and have full tread. TIA
Alpinerunner is offline   Reply With Quote
Old 01-23-2020, 07:19 PM   #2
GreaseJunkie
My Ride: 325xi
Have you replaced the bearings?
Sent from my U504TL using Tapatalk
GreaseJunkie is offline   Reply With Quote
Old 01-24-2020, 08:04 AM   #3
chrisr03325xit
My Ride: 2003 325 xit
Year: 2003
Model: 325xit
Transmission: GM
For me it's always been bent wheels which I've had easily repaired several times.
chrisr03325xit is offline   Reply With Quote
Old 01-24-2020, 08:43 AM   #4
77'911
When's the last time the diffs and transfer case had their fluids serviced(IE for drone)? Wheel bearings can be an issue. Does the drone go away when your in a corner, or is it constant? A few things that got rid of vibrations in our car was the following:
1) new motor mounts (transfer case mount is next)
2) fresh NGK plugs and new Bosch coils to replace the horrid Bremi units
3) servicing the trans (BMW factory service kit and fluid-2x).
4) replaced all the exhaust hangers
5) installed new upper ball joints, lower control arms and bushings(all factory bmw, really improved it on the hwy)
You might get the car up in the air and give it a once over. At 193k, it could be any number of factors. Hope you get it solved. These cars are fantastic when they get serviced.
regards
77'911 is offline   Reply With Quote
Old 01-25-2020, 12:41 PM   #5
Alpinerunner
My Ride: 1990 M3
Do you mean CSB? The rebuilt driveshaft came with a new CSB. I'm really hoping it wasn't a poorly balanced driveshaft but that's kind of what it feels like. What's strange is it comes on pretty quickly between 60-65 and stays constant as speeds increase (don't seem to get worse up to 80).
Just swapped wheels with a set of M contour I had lying around last night. No change.
regards
Replaced motor mounts but not TC mount. New fluids all around including trans, replaced center exhaust mounts when I did driveshaft. Didn't think of wheel bearing, that is possible. I'll have to throw it around at highway speeds to see.
