DIY: Replacing front control arm balljoints - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 12-03-2016, 09:10 PM   #1
Tippey764
My Ride: 2002 Touring
Send a message via AIM to Tippey764
I've seen a bunch of people buying new control arms to simply replace the only balljoint on the arm. I didn't want to spend $100+ on an arm when you can buy e36 all metal balljoints for much cheaper and press them in.
These are the balljoints used in my DIY
https://www.ecstuning.com/b-meyle-hd...1126758510~my/
Step 1: remove the control arm from the car, I won't be covering this part
Step 2: make relief cuts into the bottom of the balljoint cover and pop it off
Step 3: Remove the balljoint from the rubber isolating insert. First remove the rubber boot at the top to keep it out of the way as it pressed through out the bottom. One of my control arms was worn out and it came out easy, the other one I had to press the joint out, they both were fused to the rubber and tore it up on the way out You might be able to pry it out with a screw driver if you're lucky. Get creative.
Step 4: now you're left with this open hole. You're going to want to make relief cuts into the side of it ( you might make some marks into the control arm but thats fine, one or two won't hurt it. ) After you make the relief cuts start to hammer it from the side to collapse it inside the hole. After you make some progress you can hammer this metal sleeve out the bottom
Step 5: Take your new balljoint and press it into the arm
Step 6: You're all done, reinstall the arm to the car.
Tippey764 is offline   Reply With Quote
