EVAP BMW code 250 (aka P0440 or Peake FA) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-24-2020, 10:26 AM   #1
bdeibner
Hi, I have a 2000 323Ci showing BMW code 250 (aka P0440 or Peake FA). It is defined as an EVAP system ďpurge valve functional checkĒ. Iím assuming this means Iím not getting enough purge flow through the system for the ECM to recognize the EVAP system is working properly. Iím getting no other codes. Occasionally Iíll find a vacuum (or maybe pressure?) in my gas tank when I remove the cap. LTFT=0, STFT=~2. Anyone successfully solved this?
bdeibner is offline   Reply With Quote
Old 02-24-2020, 03:25 PM   #2
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
P0440: Evaporative Emission Control System Malfunction
https://www.obd-codes.com/p0440
Most common problem is a bad evap purge valve.
You can remove it and test it with a 12V power supply and vacuum pump with gauge.
