330i vs XI differentials. Different? Or the same? - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 09-25-2014, 11:30 PM   #21
Cyrus051
My Ride: 05 330IX
Missed this=P Hopefully my help can still be relevant. So here's the deal the 330 has a very much different engine than the M3. The m3 has a 3.2 litter that will have very much different electronics making that kind of swap difficult. I have seen both an AWD m3 and a 330Xi with an M engine but both would be very costly/ time consuming. You'd really have to ask yourself if you really want to put that kind of money into your car. Hey if you really want to pull this off all the more power to you! Just do your research as best as you can first. One off projects end up being a mess without help from others who have done them before. In some cases at least.
Your transfer case and transmission would be interchangeable between the 330XI and 325XI. The diffs have different ratios so you couldn't swap only a single diff from one car to another you'd have to do both. But dimensionally they would be the same on the outside and would interchange. Keep the 325 diffs as they are lower and you'll get better acceleration.
330xi 6spd E46 Sedan AWD manual
4.35
2.5
1.66
1.23
1.00
0.85
3.93
3.07
6500
325xi E46 Sedan AWD manual
4.21
2.49
1.66
1.24
1.00
3.85
3.23
6500
Hope that helps mate! Good luck!
Cyrus051 is offline   Reply With Quote
Old 05-22-2019, 06:12 AM   #22
325Turbo
My Ride: 2001 330Xi Touring
Using this old thread instead of a new one.
How about the physical dimensions? Are RWD and AWD rear differentials equal by their size etc?
325Turbo is offline   Reply With Quote
Old 05-23-2019, 11:45 AM   #23
WilloCO
My Ride: '05 330xi 6 speed
Originally Posted by Gtfour View Post
I have a question a bit off-topic.
I have a 325xi Touring and was wondering if the diffs, transfer case and tranny are the same as a 330xi sedan. The 325 feel a bit under power... I am considering a 330 engine swap to keep the xi otherwise I will buy a salvage E46 M3 and will swap everything next spring.
Also, it is possible to swap the 6 speed tranny from a 330xi into my 325xi and keep my diffs and transfer case?
Yes all the bits will bolt together, there are differences in diff gear ratios between models. Some 6 speed swaps require that a notch be ground into the lip of the transfer case, easy to do with a grinder.
Take a look at the S54 (m3 engine) XI builds out there. There are some good write-ups on the work to do it.
Originally Posted by YoitsTmac View Post
I bedded my pads when I switched from ceramic to my PDF-Z pads. They actually caught fire during bed in.
05 330xi 6 speed
RIP: 86 e30 w/E36 M3 suspension build
WilloCO is offline   Reply With Quote
