Transmission??? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 05-23-2019, 12:15 PM   #1
Kyledale4
My Ride: 03 BMW 325xi
Transmission???
I drive a 03 325xi and all was normal, one night driving down the common road I always do at 50 MPH in the middle of the winter I noticed a shake. I had pulled over within 1/4 mile and looked for ice build up underneath the vehicle. As I drove away from being parked there is a shake that had vigorously increased and had shook for about 3/4 mile at about 10-15 MPH, then shortly it suddenly stopped for about a 1/4 mile period and i could even go 40. I have now turned on my buddies “dirt” (snow) road and the shake is very vigorous at 15 MPH again. I had pulled into his driveway and instantly I had no throttle response with the wheels, only the RPM gauge.
Engine starts and runs great, transmission had no hard shifts or slips prior to this, but that grinding noise under the car sounds like an input shaft bearing and I’m trying to determine that for a fact, an experienced mechanic (GM Dealership) 20+ years said it may even just be an axle, but that doesn’t explain no wheel response in any gear
Just Looking For Help, Thank You
Kyledale4 is offline   Reply With Quote
Old 07-16-2019, 12:55 PM   #2
Kaus
My Ride: 2003 325xi
bump
Kaus is offline   Reply With Quote
Old 07-16-2019, 01:29 PM   #3
jmo69
My Ride: 03 325xi 98 328is
Year: 2003
Model: 325xi
Transmission: Steptronic
Could be an axle failure and check to see if one has popped out of the front dif. The xi AWD is a completely open system, if one component fails the car won't move.
Sent from my SM-G950U using Tapatalk
Alternative to expensive xi control arm bushings https://forum.e46fanatics.com/showthread.php?t=1231503
Bad outer xi ball joint? https://forum.e46fanatics.com/showthread.php?t=1127077
2003 325xi auto Stahlgrau
1998328is 5sp
jmo69 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-22-2019, 09:07 AM   #4
Notnrml1
My Ride: E46 xiT manual
I've got the same issue. Came out of nowhere last Thursday. Any gear, no wheel rotation. I removed the front wheel driveshaft yesterday and still no movement, so doubt its an axle. I smell the metallic scent of a burned clutch. So, it's likely the bearing or clutch. Removing the tranny during the course of this week.
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall, and torque is how far you take the wall with you.
Notnrml1 is offline   Reply With Quote
