Replaced lower control arms, ball joints, bushings.... - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 06-23-2019, 11:19 PM   #1
77'911
Replaced the lower control arms, upper ball joints, and pressed in new bushings this weekend. All of the stuff was factory and installed to spec. Shimmy(when braking, high speed) has now disappeared and steering is much tighter. Previous owner had aftermarket stuff installed which went bad quite quickly. One thing the previous shop had screwed up, was the offset for the control arm bushing(way off from 18mm) and the ball joints were shot.
I'll warn others, the passenger side was tight. Since I have a 20 ton press in the garage, pressing in the bushings was not too bad. If you don't have one, you might need a machine shop, or the like to press them in. Hope everyone had a good weekend.
Regards
77'911 is offline   Reply With Quote
Old 06-25-2019, 02:43 PM   #2
jmo69
My Ride: 03 325xi 98 328is
I press centered e36 M3 bushings into my carriers with a home built 8 ton press. The same press that I use to press in the e36 non m outer ball joints. Makes things replaceable on a budget. My guess is the poly bushings I have in my e36 would fit too. I can do out ball joints and bushings for <$70. I should do the inners one of these days but the car drives just fine.Click image for larger version
ID:	778289Click image for larger version
Sent from my SM-G950U using E46Fanatics mobile app
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 06-25-2019, 04:22 PM   #3
77'911
I'm going to see how these wear. Since I now have an extra set of lollipop brackets, I might prep them for urethane on the next go-round. My experience, is, the factory stuff tends to last much longer. I used a 20 Ton Arcan shop press which was adequate.
Regards
Sponsored Links
Advertisement
Old 06-26-2019, 12:08 AM   #4
jmo69
I use the Lemforder bushings and Meyle HD all metal ball joints. Holding nicely so far, ball joints have been in for a few years and the bushings for a year.
1998 328is 5sp
Old 06-26-2019, 02:58 PM   #5
the fly
My Ride: '95 m3, '03 m3
Regards
The statement about factory stuff lasting much longer is true for FCABs across most BMWs. However, the XI units are fluid filled unlike the solid rubber used in the FCABs for other variants. That means there's less rubber to resist deflection and it wears much quicker.
PM me if you're interested in selling your lollipops. I do an FCAB pre-pressing service for forum folks.
Need FCABs? I sell them pre-pressed...
the fly is offline   Reply With Quote
Old 06-29-2019, 12:48 PM   #6
77'911
The bushings in our lollipop brackets had no fluid, but definitely less rubber then a M3 unit. Thanks for the offer, but I'm thinking of keeping the brackets around as insurance if I go the urethane route on the next go-round.
Regards
Old 06-29-2019, 06:03 PM   #7
infoboy
My Ride: 325ci
Originally Posted by jmo69 View Post
I press centered e36 M3 bushings into my carriers with a home built 8 ton press. The same press that I use to press in the e36 non m outer ball joints. Makes things replaceable on a budget. My guess is the poly bushings I have in my e36 would fit too. I can do out ball joints and bushings for <$70. I should do the inners one of these days but the car drives just fine.Attachment 778289Attachment 778291
Can you do the same with non xi cars?
Sent from my SM-J415F using E46Fanatics mobile app
infoboy is offline   Reply With Quote
Old 06-29-2019, 11:58 PM   #8
jmo69
Not that I'm aware of. The non xi control arms are quite different from the xi. Aluminum compared to steel for one.
1998 328is 5sp
Old 06-30-2019, 11:28 AM   #9
infoboy
My Ride: 325ci
Okay thanks for the reply.but im curious whats is the fitment difference between the xi control arms vs non xi arms
Old 07-01-2019, 12:14 PM   #10
the fly
I offer the Z4M solid rubber bushings for non-XI / non-M e46. They are offset which adds a bit more caster angle, but are solid rubber.
https://forum.e46fanatics.com/showthread.php?t=1000825
Old 07-01-2019, 11:10 PM   #11
jmo69
You need to google some pictures of the 2 chassis' to see the differences. These are the xi control arms. https://www.fcpeuro.com/products/bmw...6xi4piececakit and the RWD look like this https://www.fcpeuro.com/products/bmw...-e46-e46arms-l
1998 328is 5sp
